Cylinder Solvent Flush Candidate?
jliltd
Benefactor
I started a condition inspection on my RV-8 with IO-360. When I removed the bottom spark plug from #3 I had about a teaspoon full oil come out, and appeared to be cut by a bit of avgas so it was more "fluidish". Prior to the plug removal I did a compression check on #3 using the upper spark plug hole for the compression tester. It came in at 78/80. This was a test with engine hot after a little more than an hour flight.
This engine has 415 hrs TTSNEW and170 hours on a Barrett major with 170 hours on brand new Superior through-hardened steel cylinders.
Later today I will re-run a cold compression check on the cylinder.
I got my borescope camera and looked inside and found evidence of oil. In fact there is a a wet creek of it along the bottom of the cylinder wall heading for the bottom spark plug hole. The drain path that leaked out of the hole when I removed the spark plug. The edge of the piston is shiny wet with oil. See photos. Ignore the date stamp as my camera wasn't set.
I see mention of the cylinder solvent rinse process that can help loosen up stuck rings and get the oil control ring back to working properly. Would this cylinder be a good candidate for the solvent flush process as presented by Aircraft Specialties Lubricants and SAVVY?
IMG_0015.JPGIMG_0017.JPGIMG_0021.JPGIMG_0027.JPGIMG_0028.JPGIMG_0029.JPGIMG_0032.JPGIMG_0034.JPGIMG_0035.JPGIMG_0044.JPG
What is your oil needs between oil changes and hours between change and add oil? Is it consuming/burning, or blowing by? Catch can empty, more than usual oil on belly, or do you push blow by back into engine? If consumption flush may help. If blow by less likely.
I had a similar situation with good compression but oil leakage fouling plugs and burning excessive amounts of oil. In the end, I found that there was a small crack leaking oil into the combusion chamber fouling one of the plugs severely. I replaced that cylinder. I'd do the flush but keep in mind you could have a crack.
I did a cold compression just now on the subject cylinder and it held steady at 76/80. But there was small amount of air heard from the dipstick filler tube. No noise from exhaust. Intake was indeterminate with the snorkel and everything but it didn't seem to be making noise. I would call the valves good and the rings the culprit. Would this warrant the solvent flush process or am I just pis@#$g up a rope?
so, if the noise is in the crankcase, the leakage is past the rings. So anything that might help the rings is worth trying.
The solvent flush might help. If it was mine, I'd try it.
Curious about the remark above where a crack in the cylinder was causing oil to get into the cylinder. Huh. Where was the crack? There's no pressurized oil in a cylinder so I'm having a hard time understanding how that could work.
Ive got same symptoms, about same pressure cold check #3. Im currently running seafoam 1oz each qt in sump hoping it cleans up some stuff in the lands. Mine is mostly all blow by, not burning it. Seems to consume 1 qt per 10 hours. Ive held off on flush since its main purpose is to clean oil control ring passages.
I quart in 10 hours sounds like pretty normal oil usage to me.
Not horrible I agree…..but up from previous 6 months, catch can and belly shows it. The breeze coming out filler neck is surprising with 76/80 !
I'm going to try some Liqui Moly Engine Flush in my car at next oil change. Oil consumption is creeping up (189,000 mi). Plan is to put in just prior to oil dump, run gently for a short while, then dump it. Time will tell, but some folks have had luck with it on Volvo and Audi engines. FWIW! But for an aircraft engine the solvent flush (as described by Mike Busch) would be my go-to.
This video addresses engine oil additives, and spoiler alert, they are not recommended.
The solvent ring flush is very different from the engine oil additives discussion.
It's not going to cost you much to do the ring flush.
I have an 560 hour 0-360 with SDS fuel and air running Costco premium channel chrome cylinders 1-6 oil consumption. Did ring flush and went from 1-5.5 to 1-6. Blackish Phillips 20/50 XC oil by 10 hours. always change at 25.
Got a weird vibration in the "prop" and after much looking, trying, asking, and hand wringing, I pulled the motor cause people thought the front main bearing was toast.
BUT I found #4 cylinder had a top ring broken. It is tore apart on my engine bench now.
I had a second engine in my hangar.
Hope you do not experience the problem.
Oh by the way my compressions were 80/78 with no noise anywhere BUT I had oil in the cylinders like you.
AND the vibration was a wheel pant that had two slightly loose rivets.
My luck varies FIXIT
And --- oil additives (put in and LEFT IN) is a different discussion than using a 'flush' treatment. I was not advocating for adding some additive to the oil (and leaving it in) in order to possibly clean/unstick rings. My opinion is anything in sufficient concentration or sufficient 'eat stuff' characteristics is probably not a great lubricant. Personally I won't put snake oil into my engine and then go subject it to high load (as in take off power).
View attachment 65378View attachment 65379View attachment 65380View attachment 65381View attachment 65382View attachment 65383View attachment 65384View attachment 65385View attachment 65386View attachment 65387
I am curious what scope this is? Would you buy it again? I was shopping yesterday.
I am going to throw a new thought. What I see in the picture is oil flowing from the top down to the bottom of the cylinder. The question I would ask why is oil flowing from the top down into the cylinder. I do not think that rings will cause that to happen. It seems that the oil which is being added from the push rod tubes flowing into the cylinder is where I would start looking. The bottom rings do not sit constantly in oil, ie...that would allow oil to flow into the cylinder. Yet even then, when the engine is not working no oil is flowing into the rocker arms. A crack seems possible, somewhere. Well, my thoughts are only worth a puff of wind.
I have some oil in one cylinder but no fouling. I recently overhauled the motor myself and my IA thinks I put the ring gaps on the bottom of the cylinder (no they are not lined up). I intent to fly on unless the plug starts fouling regularly or the consumption increases.
Two-Way Articulating Borescope with Light, Teslong 5-inch IPS Endoscope Inspection Camera with Articulation Head. $249. Found at your favorite online mega merchandise seller. I would buy it again.Bore Scope.jpg
That oil is not flowing from the top to the bottom of the cylinder. The cylinder is horizontal not vertical. So the oil is coming in horizontally and the line of oil seen in the photo is the bottom of the cylinder (horizontal cylinder wall). That's why the oil only came out of the lower spark plug hole and not the top spark plug hole.
Further results on the issue. So I did the ring solvent flush process by mixing up the jungle juice in a 5 gallon bucket per instructions. Was able to get solvent to run out of the sump. After that I did a 8 minute run up on the ramp and then re-scoped it. Oil in the cylinder again. So I pulled the 170 hour cylinder and piston. The ring gaps were with 50 degrees or so of each other but none lined up. Decided to buy a new cylinder assembly, which comes with an 8:1 compression piston. Since my 9:1 piston uses a different part number I figured I would buy one of those too. But since my piston was match weighed with the other 3 pistons within 2 ounces I needed to get one within the same weight. Unfortunately all the same p/n from Superior are almost 100g lighter which is way out of range. So I am sending my piston and cylinder to Rhonda Barrett at Barrett Precision in Tulsa for clean up and rework. Meanwhile my hangar neighbor had a brand new in the box cylinder power assembly that was the same exact part number so I bought that for to go with the reworked original piston and I will have the original cylinder reworked by Barrett as a spare.
As an aside. What can I do with the left-over 2 gallons of solvent mix? Seems pretty volatile and don't think it might be good in a parts washer. Maybe keep it in the bucket and get a carb cleaner basket to go with it for dunking dirty parts. I certainly don't want to pour it into my oil recycling tote.
Well too late now for you, but I wonder if just an 8 minute run-up is enough? I went back and read the how-to and it doesn't say anything about expecting instant results or not. Maybe someone who knows can add that info to this thread.
We’re most of the ring gaps on the bottom of the piston/cylinder ? That’s what my IA thinks is going on with mine.
Jim, was there anything in the cylinder that looked like it was bad or broken or the cause of the oil? Were any of the rings stuck or any of the grooves full of gunk? Perhaps you can share some pictures of the rings and the piston. Thanks!
Excellent question. Unfortunately I can't say as we didn't think of that. The guy helping me pull the cylinder removed the piston while I was carrying the cylinder across the hangar. I will ask him if he remembers. I wish I had had somebody like your IA for consultation.
No rings stuck and the ring grooves looked fine. Ring edges were shiny. There was a bit of scoring/scraping on the piston side. And then there were some very light pits on the cylinder wall. Both were very light and the piston lines were barely detectable when drawing across with a finger nail. These are steel cylinders with 170 hours. No signs of rust and I live in the dry desert. So I am thinking maybe some FOD. Valves are perfect. See additional photos.
Yeah. After the solvent flush the cylinder was squeaky clean and devoid of oil residue. Then the sump was re-filled with oil prior to the runup at an ambient air temperature of 104 degrees F. So to me it was surprising for the same amount of new oil to show up in the cylinder after only 8 minutes. That was my trigger for cylinder removal. After a similar volume of new oil showed up in such a short time I wasn't concerned with giving the solvent flush process any merit for long term improvements. At that point It had only served a purpose of cleaning the prior run oil out of the cylinder and sump.
As un update to my prior post, an IA that that helped me pull the cylinder told me today he did an inspection of the piston rings right out of the cylinder prior to setting it down and said the ring gaps were in fact towards the bottom with one at bottom and the other two with 10 to 15 degrees from bottom. He didn't let it get by him. So yes. That was probably the majority of the problem. New ring gaps were installed 120 degrees apart, with oil control ring gap on top and the top and center rings at 4 o'clock and 8 o'clock.
Since my original new piston was 1382 grams and other pistons in stock of same part number were around 1295 grams Rhonda Barrett suggested instead of buying a new piston that I re-use the original piston as it looked fine. Barrett assembles their engines with pistons weighing within 2 to 3 grams of each other. So there was concern about the imbalance of having one 87 grams lighter than the other 4 pistons. I sent the original piston to Barrett and they cleaned it up and inspected it and sent it right back. A quick turn for Oshkosh. I was able to buy a brand new steel through-hardened cylinder assembly of same part number as original for $1400 from a hangar neighbor and re-used my cleaned up 9:1 piston with the new cylinder. The new cylinder assembly is shipped with a 8.5:1 piston as standard so that was set aside. We got the cylinder it stabbed and the baffling re-installed this morning and did a quick start up an leak check per the Superior service letter and Lycoming service instructions. The temperatures here have been 100 degrees plus every day. Since my density altitudes are in the 8,000 ft + range I will delay first flight until the cool wee hours of the morning in an attempt to allow the engine to develop 70% or greater power for the break in. I will be doing some RTV sealing of the baffling as per original configuration tomorrow and probably fly crack of dawn on Monday.
I have a 2 1/2 gal fuel jug to store the fluid til next years flush cycle. it is now my annual procedure. great diagnostic tool. very messy though. done with a lot of cardboard under the engine. my oil consumption has reduced a lot.
I think I will just live with a little oil settling in the cylinder after shutdown unless it starts to regularly foul the plug.
