I've read several places not to rotate the crank when cylinders are taken off the engine. However, cylinder removal instructions say:
Rotate the crankshaft to place the piston of the No. 1 cylinder at top center of the compression stroke.
Removal of the remaining cylinders and pistons may be done in any sequence, but less turning of the crankshaft is involved if the cylinders are removed in firing order 1-3-2-4.
This is the procedure I followed - should I be worried about turning the crank during this process?
