Design C.G. Range.............................18%-29% of wing chord OR 82.08 - 88.24 inches aft of datum.
As the aircraft manufacturer, did you change the positioning of any of the big flat bits? Wings and tail-feathers? If not you would be well advised to stay within the design CG range.
When an aircraft's center of gravity (CG) is at or beyond the extreme limits, it can drastically alter flight characteristics, making the aircraft difficult or impossible to control. Forward CGs can lead to increased stability but may hinder maneuverability and control authority for takeoff or landing.Conversely, aft CGs can cause instability, potentially leading to violent stalls or uncontrollable spins
