Creating a Weight and Balance Envelope
rockitdoc
I rooted around a bit here and on the net and came up pretty empty. Anybody have a good source for setting up a weight and balance envelope? I've weighed my bird empty and have the arms and weights of the gear and location of the firewall. All arms measured 72" from the leading edge of the wing.
I'll look, but won't it vary depending on empty weight?
What he meant was, the method of measuring, and the various moment arm lengths, and the allowed limits, are all in the documentation.
Many people enter the measurements, and then that day’s conditions (pilot weight, passenger weight, bag weight, fuel on board, etc., into a spreadsheet, which then does the required calculations to show total weight plus cg location. My personal Excel based spreadsheet even calculates cg at zero fuel (landing), as the cg moves on most RVs as you burn gas.
There are sample weight and balance forms for download towards the bottom of this page. You should be able to download one, update the empty weight and CG numbers to match your airplane, and go forward from there. If you need help creating a spreadsheet from the .pdf, you're free to reach out to me...
Design C.G. Range.............................18%-29% of wing chord OR 82.08 - 88.24 inches aft of datum.
As the aircraft manufacturer, did you change the positioning of any of the big flat bits? Wings and tail-feathers? If not you would be well advised to stay within the design CG range.
When an aircraft's center of gravity (CG) is at or beyond the extreme limits, it can drastically alter flight characteristics, making the aircraft difficult or impossible to control. Forward CGs can lead to increased stability but may hinder maneuverability and control authority for takeoff or landing.Conversely, aft CGs can cause instability, potentially leading to violent stalls or uncontrollable spins
...for Normal category (I believe...might be Utility category). Aft limit is 86" for *aerobatic* category (and a lower MGW). That's for the 14A, per the documentl.
