Cleveland Brake parts
Plummit
Friend
My -10 has Cleveland Brakes with a part number of 3059E. The last time I relined the brakes I used Rapco 66-112 RV-10 pads purchased from Desser Tire.
I thought I would be able to buy the pads and rivet them to the plates in preparation for a re-lining, so I would be able to install them more quickly, however I have been unable to locate part numbers for the Cleveland brakes.
Does anyone know or have info on the 3059E brakes?
~Marc
Did you try Parker - Cleveland - parts catalogs?
Have you gone to the source?
http://www.parker.com/literature/Ai... Static Files for Literature/AWBPC0001-19.pdf
do control-F to search the page for 30-59E
It has all the part numbers - Is that what you needed?
edit: 066-10500 is lining part number -apparently widely available, but you will need the backing plates($175.00 Yikes) For that price, I will be getting the tool and rivets. Oh - ACSpruce has the parts diagram too.
Yes I finally found the part numbers for the backing plates and YEOW! That's some expensive steel! OK, I'll try a WTB post in the Classifieds.
~Marc
I need one backing plate for my RV 4 as the holes are becoming enlarged on one of the ones that I have. The RV 4 plates are almost as much. Ridiculous for something like that.
Tim
