I finished my canopy frame over the winter and now that the weather is getting warmer, I would like to fit the cover. I had a question about fitting though.
The pictures in the manual seem to show the initial fitting prior to splitting in two parts is done with the top horizontal brace (ties into roll bar) removed. It would seem like that would have to be removed to allow the canopy to be moved about and slip in and out.
Is this correct? If so, I assume that I would install the brace after the canopy is split, but not yet installed. Or does it get installed after the rear canopy section is installed.
I appreciate your guidance here.
Larry
Larry
