rcsilvmac
I am not very mechanically inclined, but my RV-6A is insisting I learn. I recently had the right brake lose pressure. Of course I need to bleed the brakes...so I spent the better part of a day figuring that out, then discovered that I had a leaking Cleveland master cylinder on the left pilot pedal. After researching this item, it seems the prudent thing to do is to replace it with a Matco one. Should I replace both on that side? What is the right replacement Matco part to purchase? Any advice before I embark on this next project? How do I keep the brake fluid from draining out all over my interior?
Thanks, and go easy on me!
