I am trying to understand the brake system in my RV6
Here are the left side brakes:
The lower black hoses come from the firewall. The upper black hoses are routed to the right side brakes in the lower position.
Here are the right side brakes:
The lower black hoses come from the left brakes.
The upper plastic hoses go to the firewall.
I have good pressure on the left brakes, and they work properly.
The right brakes have no pressure at all. The pedals will move to to full extension and I am not able to pump up the brakes on the right side?
I can see small drips in the plastic line fittings.
Here is a picture of what I think is the in-source of hydraulics for the left brakes. This is on the lower firewall behind the left brake pedals.
Here is a picture of the out-flow of hydraulics coming from the right pedals.
Are the gold metal blocks that have hydraulic hoses coming in and out, the master cylinder for the respective brake?
How am I able to have brake pressure and working brakes on the left, but no pressure and no working brakes on the right?
Are these brake systems completely independent of one another, but share a common hydraulic reservoir?
TIA
Frank
TIA
Frank
