rightrudder
Hi guys,
I'm getting read to drill some holes in the side rails for the rudder pedal mounts. If I butt the plastic bearing blocks up against the firewall corner brackets, will there be sufficient travel for full rudder deflection? I'm gonna make two sets of holes so I can move the assembly back a bit if needed, pending the final test-sit with the seats in place.
