When I installed the fittings for the reservoir brake lines I encountered that the brass insert did not fully bottoms against the end of the plastic tube.
No matter how hard I pushed (right after it has rested long enough in boiling water) it sticks out by .053".
I am unsure if that is ok, or if I will face a leaking problem later on because of that.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I may add, that I didn't drill the tube with a #29 bit as the instruction says in chapter #5. The instruction where the brake lines are made do not call for any enlarging the tube diameter.
Thank you very much for your opinion on that.
![1r5jsz.jpg](/proxy.php?image=http%3A%2F%2Fi67.tinypic.com%2F1r5jsz.jpg&hash=b70c74ec15f78ecae29599869f320e37)
