Bowden Cable Clamp
Make your own clamp
I didn't really care for the Spruce part - it didn't seem to really clamp all that well when I tried it. It's also aluminum so its not fireproof.
FWIW HERE is what I did to solve this problem - make one out of an AN832-3 fitting. Its pretty easy to do.
I thought they were steel, well, that explains why no-one appears to be using them! I knew it was a stupid question, but didn't know why. I'll check out your method! Thanks
I learned something to - feel stupid about it now. Used three Bowden clamps on cables thru the firewall. Assumed they were steel and didn't even bother to check :(. I guess a guy could make some out of steel or do something like Don did.
Thanks for bringing this up.
I had foreseen to use such a bowden cable clamp for oil cooler air door cable... until I tried it: It does not clamp very well. So I will have to come up with another solution.
I decide to use Dan's method and ordered everything from Spruce yesterday. I did a pretty comprehensive search on the web and if you are looking for a bulkhead passthrough method that protects the cable, clamps it in place, and is steel...well, I couldn't find it.
I drilled two 3/8 hardware store bolts for this purpose. No clamping, but needed to do that at each end anyways.
