Problem:
Unable to service the Scavenge filter on the Barrett Sump.
The Filter in question is 4 1/8" long and resides in the rear of the sump. It is not possible to remove the filter to clean and inspect as it interferes with the Nose Gear leg support.
To make matters worse, the Barrett supplied fitting that retains this filter is a custom machined elbow. The elbow must be reinstalled and "clocked" to the correct location to align with the heavy #10 oil pump feed hose. Now "clocking" this already weakened fitting, takes more HP than I would ever like to use on an engine.
Barrett fitting on the Right.
Tom at TS Flightline and many others have exhausted all known parts bins to find a suitable answer. the current version is to remove the scavenge filter and install an inline much smaller filter from Dry Sump Solutions that can be serviced easily at every oil change.
The Scavenge filter from Dry Sump Solutions is correctly installed at this location.
In another thread, experienced maintainers have all chimed in with very heavy sludge blocked scavenge filters that would make the filter capacity of the Dry Sump option not suitable.
What is required is an external in-line,CNC machined, serviceable filter that still retains the capacity of the original scavange filter. Something that would fit at this location shown below and machined so as to delete the adapter stack that is currently employed.
Looking forward to the VAF collective solving this problem.
