I am probably way over thinking this but first time dealing with this type of fitting. I am going to install this into my beringer brake master cylinders are my questions;
1. Is the left item accurate that I will sandwich the banjo fitting between the two crush washers?
2. For the alignment holes of the bolt is there some marking somewhere I'm missing or should I just mark the top so I know where the holes are?
3. Once I connect to torque should I go to the torque spec and then tighten enough to align of the two bolt holes?
Appreciate the help, didn't want to guess this and the guides I found online essentially said "Align holes, torque to spec"
