I can sure use a little guidance on installing the Archer antenna in the wingtip.
-How did you mount the antenna?
-How is it connected to the coax?
-Once the wing is installed is it difficult to route the coax thru the fuselage?
Thanks!
The ground leg needs to be mounted, physically and electrically, as close as possible to the end rib. Method (1): Before mounting nut plates to the wingtip (or remove them if already done), place the ground leg between the wing tip and the nut plates; match drill wingtip and antenna ground leg at all places. Rivet wingtip - ground leg- nut plate. Remove all paint from the wing under the attaching screws, so there is a good ground leg to wing metal to end rib electrical connection, at many places along the ground leg.
Thanks!
Sure thing, you should be able to do that at the wing root. You just want to avoid changing the connection to the antenna itself where the coax splits out to the center conductor and shield connections, which it doesn't look like you want to do.I know it has been a couple of years since this topic was raised, but if anyone has an answer or an opinion I would like to hear it to this question: Can I put a BNC connection in the coax at the wing root and get acceptable performance. I would like to treat the coax like the other electrical systems and use connectors at the wing root.
