I installed the wings in my garage to set incidence, then again for the final time in the hangar. Both times it was just me and my A&P/IA brother in law. He was on the wingtip, I was inboard. I had a couple of big yeti style coolers and furniture pads under the wing in case we had trouble getting it in and needed something to sit it on while regrouping, but they went in on the first try.
Sprayed the spar ends with LP3 to make them a little more slippery. Once we had them started he continued to hold the tip while I crawled in the plane.
Once inside, I reached back over the side and lifted up on the inboard edge of the wing while he pushed. I used a flashlight and inspection mirror to get an inboard hole aligned well enough to install a drift pin made from a hardware store bolt with the threads ground down. Once I had that in, it was simple for him to wiggle the tip up and down to get another hole lined up.
I had everything I needed either in the plane or on a shop table that I could reach while I was inside. Hardware, plans to show the washer stackup, a couple of soft hammers, Wooden dowl to knock the drift pin back out, a couple of small pieces of aluminum skin scraps to to encourage the lower wing skin to not get caught on the fuselage skin and to funnel the aft spar into the fuselage carry through fork if it got hung up, stuff like that.
The real bolts are close tolerance. They're going to have to be tapped in for final assembly. I put a block of hardwood on the head and then tapped that with a brass set in a rivet gun turned down low.
Think it through ahead of time. Have everything you need within reach before you start. It's not super hard. Without the flap & aileron the wing only weighs probably about 80 lbs or so. It's pretty easy for two guys to maneuver around.
