Hello all I've just about talked myself into following in Brain Kelley's footsteps, but before I get too far down the "rabbit hole " I would like to get some advice from some experienced RV's. First I don't know anyone with a RV-8 I'm based at KFVX in Farmvile VA and I would like to meet and discuss some particulars that Mr Kelley had to overcome with his build. Second the standard gear is intended to accommodate up to a 76" prop while the Rotec R3600 is designed to swing an 84" I spoke with Grove Gear about the possibility of taller gear and they suggested using a one piece set that would also reduce stress on the fuselage if the gear web was 5" or more wide where it's mounted , Now on a quick build kit would it be advisable or possible to add additional gear towering ( example adding an additional front & rear tower panel about an inch fore & aft of the factory installed ones.)
Thanks in advance for your help, as many more questions will follow. Morgan D.
