The Question(s) Up Front (TLDR)
- RV14 build in Australia
- Planning for SDS EFI installation
- Originally planned a factory new IO-390-EXP119, but with all the trade uncertanty and the s&*t dollar, the massive lead time, the thunderbolt price hike etc i have had to rethink things. Or sell some kids.
- Have purchased an IO-360-C1E6 core, soon to be overhauled i hope (converting to front induction sump - probably standard lycoming one).
- Previously purchased the EXP-119 Finish kit, so this came with the Dual Pipe style Cowl. (see pic).
- Thanks in advance to anyone who can provide some insight - i have never ordered, or fitten an exhaust system before. (i have asked Clint if he can advise via email also).
What exhaust will fit this engine / cowl combination best?
The options are
- The IO-390-EXP119 Exhaust Kit (crossover, dual pipe) which i know will fit the cowl, but not sure about if this will fit the engine, or
- The RV7 IO360 200HP Exhaust Kit with Heat Muff (crossoever, dual pipe) which should(?) fit the engine, but not sure about the cowl! or
- Get one or the other, and have a local welder make whatever changes are needed to make it work (we have a great welder here).
The second question:
It will be prudent to replace the starter (i think) on this engine. Van's sells a baffle kit suited to both the IO-360 and io390 for the RV14 and this comes with the VA-132-2 snorkle.
What starter is best suited to the VA-132-2 Snorkle?
Some background into the Snorkles:
From what i can find on the Van's store, these are the snorkles used in kits:
From reading this, the VA-132-2 seems the most appropriate, but not sure of what specific starter ("lightweight Skytec starter") they are referring to. I am not too concerned about the fuel servo - the SDS throttle body utilises a silicone tube on the front, which gets mated to a 2 1/2" aluminium flange, which can then mount to the snorkle.
More Background
As some more background, i wanted to see if it was worth ordering the Van's RV14 EXP-119 Firewall Forward Kit, or better off ordering just what i needed from the kit contents. So i made up an inventory in excel. It has worked out to be a very similar price, but i think i am getting closer to what i want / what will work for my engine (i hope).
If anyone is bored, here is a link to the spreadsheet.
In summary, these are summary of differences to the standard FWF kit:
Thanks in advance to any knowledable souls who can enlighten me - i'm hoping to hear "nah, all exhausts are pretty much the same"... but since this is experimental aviation...
The options are
| The IO390-A3B6 FWF kit comes with the VA-132-2 Snorkle. The EXP-119 FWF kit comes with the VA-271 Snorkle. |
| Van's Site says about the VA-132-2 "The VA-132-2 snorkel is designed to be used with horizontal induction angle valve IO-360 engines, with a lightweight Skytec starter, and fuel servo Bendix clones (AVSTAR, Precision Airmotive) VA -132-2 will not work with FM-150C Airflow Performance throttle body." |
| The EXP119 Snorkle is the VA-271 Snorkle which Van's says: "The VA-271 snorkel is designed to be used with horizontal induction IO-390 EXP119 Lycoming engines, which utilizes the Airflow Performance FM200 fuel servo." |
| Thre is also the "FAB-HORIZ INDUCTION-2" which van's says: "System includes ducting, filter, filter box and hardware. For Bendix / Precision Injection Servos. This "snorkel" airbox is designed to fit around the starters supplied on new 320/360 engines from Van's, the Skytec LS series. Other starters may require modification of the airbox." |
More Background
| Overall a Similar price to the RV14 EXP-119 Firewall Forward Kit |
| Removing all Fuel Hoses & Fuel System (red cube etc) |
| Ordering Oil Hoses Locally (except Oil Pressure Line) |
| Remove All Wiring |
| Removing Mixture Control (not needed with SDS) |
| Replacing Throttle Control with McFarlane Vernier (personal preference) |
| Replacing Master + Starter Soleniods with B&C Units (personal preference) |
| Replacing Plane-Power Alternator with B&C LX60 (obviously!) |
| Removing the Battery (Getting Locally) |
| Replacing Hartzell Governor with Jihostroj Unit (Price) |
| Ordering Complete Engine Baffle Kit (which uses the VA-132-2 Snorkel (see notes above) |
| Ordering the EXP-119 Exhaust Kit, but removing all exhaust and heat muff componets, and potentially ordering "EA EXHCO 7/7A IO-360" instead. |
| Adding the PC Steel Prop Control Bracket |
| Adding a new Starter (Skytek 149-12 XLT) - need confirmation this will work with the VA-132-1 Snorkle (this is not included in price comparison totals) |
| Adding Monkworkx Backup Generator |
| Adding Aluminium Flange (10350-10) to interface SDS Throttle Body silicone tube to Snorkle |
| Additional Costs are the SDS EFI system, and any additional hoses this required for the fuel system installation |
