The electronics shield on our Alternator is cracked. They don’t sell the part so not sure if there is a place I can get one or if I should repair.
It’s a 60 amp Plane Power and looks like it was damaged when I shipped it for a checkup.
If fixing I was gonna at least stop drill the two crack lines.
As for bracing at the two full cracks I have thin metal…probably aluminum… that I can bend/cut into shape then use either JB Weld…never a fan…or silver solder paste that is good up to 450 degrees. Just not sure if that temp is too low.
Any and all ideas are welcome.
