Doug Rohrer
I am building an RV-14A, day/night VFR panel. No IFR. This is the same configuration I have in my flying -9A which I really like. I will have FlyLED Works strobe/navigation/landing lights in the wing tips. All Garmin G3X panel with one radio. I am considering going with a B&C vacuum pad drive alternator in place of the conventional belt drive unit. I will have one Odessey PC680 battery and the Garmin G5 unit will have its own standby battery. Pitot is non-heated. B&C has several rear drive alternators in the 20-40 amp range, which would be plenty for this configuration. I also like the idea of moving a little weight aft, as I understand the -14A with a CS prop can be a little nose heavy. Can anyone think of a reason the rear drive alternator idea would not be so good?
