My fuel pump went out a couple weeks ago. It was an E2315. I order one online and the pump says not for marine or aviation use. When I looked on the forum many say it's the same pump used on Airflow Performance. Is E2315 the same pump Airflow Performance uses?
What would be the difference between auto, marine, and aircraft? I would assume the one used for boats would be more resistant to corrosion, but other than that is there really a difference?
Daren
Daren
