Well, I decided to weld the W-818 pushrods. I was careful to get the exact length that the plans call for on the cut, 23 13/16". After the rods were installed and the W-730 bellcrank jig in place, I'm a whole 1/8 inch difference on the number of threads that are in the rod end bearings. the plans show almost 5/8" of the threaded shank inside the bearing, and all I have is 1/2" on both ends. After searching DWG-15A and the construction manual I can't find anything that has a minimum number of acceptable threads inside of the rod end bearings. I imagine this is acceptable, but has anyone else run into this?
![34fg1au.jpg](/proxy.php?image=http%3A%2F%2Fi62.tinypic.com%2F34fg1au.jpg&hash=218951159ca2fe638b7bc39e5348ccd9)
![fmpaxl.jpg](/proxy.php?image=http%3A%2F%2Fi57.tinypic.com%2Ffmpaxl.jpg&hash=861fb008918992d83c16d2c6086ec46b)
![e658pz.jpg](/proxy.php?image=http%3A%2F%2Fi59.tinypic.com%2Fe658pz.jpg&hash=5c7b8145d19c1a1602c8294ca8a1a83a)
