Calling aero-structures guys or any ME that remembers Mechanical of Materials.
The plans for wingtip attachment call for CS4 rivets. I'm going the hinge attach route.
Potential problem =
- Wasn't thinking (over a couple of days). Installed 3/32 AN426s instead of intended 1/8s. Besides, why look at a drawing detail you (think you've) memorized?
Assumptions =
- The CS4's could get a 2D edge difference on a good set; only 1/2 inch aluminum available past rib.
- Original calcs I'm sure assumed only 2D edge distance anyway.
Math =
- The Shear tear out load calculated for the 0.025 2024T3 I get is 234.4 lbf. No margin given for the dimpling.
- The shear load of the 3/32 AN426 = 180 lbs (using 26000 psi shear strength and area in bearing)
- The stated shear load of the CS4 = 162 lbs
Anecdote =
I've seen plenty of wingtips that utilized threaded or 1/4 turn fasteners that obviously have less than 2D ED which would significantly affect the allowable shear forces.
The relative strength of the blind 1/8 and solid 3/32 rivets would seem to indicate I'm OK. It's been too long since I've played with such and my component property numbers came from an internet search. Anybody?
@David Paule This sure sounds like your briar patch.
Thx.
Potential problem =
Assumptions =
Math =
Anecdote =
Thx.
