Adding brass elbow fittings to Facet 40135 pump,
Hi all,
Got a Facet 40135 pump, it would fit better if I used a 90 elbow into the pump. But since there are at least 359 degrees of fit that would be the wrong direction, how far down can you tighten a brass 1/8 NPT->1/4" barbed fitting down?
Or, how about a banjo fitting like this? https://tameson.com/products/f293h-...barb-with-male-threads-nbr-rotatable-2-pieces
Hi all,
