I'm installing a DJM two lever throttle quadrant in my RV-8. I wanted to slightly extend and modify the throttle handle shape, and to incorporate a flap switch in it. I drew up the new handle using Freecad, with a cutout to match a three-position switch https://www.digikey.com.au/en/products/detail/e-switch/RRG31C31100/3778127. The switch clips into place and is held by the cutout edge.
Printed the handle on a Bambu P1S, using Bambu PPA-CF filament. Laser printed a dry rub-on transfer flap switch label and applied it to inboard end of handle. Then sprayed handle and label with epoxy matt clear coat. Came out fairly well, better than my photography capabilities can show.
I thought about just having a flying lead from the outboard end of the handle for the flap wiring, but eventually decided to re-make the throttle lever with a conduit down the aft edge, taking the wiring through the quadrant and its mount. The handle's STL file is attached.
