That's a pretty broad statement.I would not rely on FDM printing for anything aircraft related, but that is just me.
I do all of my aircraft-related parts in HP-MJF.
HP-MJF Nylon 12 is a decent choice. Go to Xometry.com and you can get quotes to have parts made. If you choose the international option, the pricing is pretty impressive.
-Chris
Related, this just in:
Plane crashed after 3D-printed part collapsed
The aircraft was completely destroyed after a spare part bought at an air show in America collapsed.ca.news.yahoo.com
We have extensive and excellent experience with FDM parts made from US-produced PETG filament made by Atomic Filament in Indiana on our Bambu P1S printers. But as with any material, one must take its application and environment into consideration. We have not made anything that would be exposed to the heat of an engine compartment, where we would likely use a high-temperature, flame-retardant composite using ProSet epoxies. FDM parts that are externally located should be sealed with paint/primer or clear-coated since they are not 100% watertight. Quality PETG filaments include excellent UV inhibitors and are quite appropriate for homebuilts, we believe. They are also naturally flame-retardant, although special flame-retardant filaments are available. We would not use them for any load-bearing applications, at least not yet. The technology is advancing rapidly and can not be ignored since the cost savings are considerable. See what we are doing now at aerosouth.net We will be adding a few more PE / FDM fairings soon.Was reading another thread and had a question. But I don’t want to send someone else’s thread off the rails.
Do we have any 3D printing experts on the forum?
How hard is it to print with the ULTEM filament? Is there a specific type of printer needed?
Back to making sure the material matches the application, it would be interesting to know what that part was made of. The ULTEM material originally mentioned has a glass transition temperature of 270C/518F, which should be fine for engine compartment parts (still need to look at other characteristics). At $500/kg for ULTEM filament those parts will be expensive. A number of commercial 3D print services can also print the parts using metal powders or metal infused plastic that is post processed to an all-metal part.Maybe I’ll re think that. Perhaps I could use the 3d printed example in making a part out of fiberglass/epoxy, like the snorkel is.
Is ULTEM 1010 the same as PRUSA's PEI 1010? If so, a mere $11,380 will get you the appropriate PRUSA printer.ULTEM would need a 400C rated nozzle and a 160C rated heated print bed.
You really need to match the material properties and the application use to get the best result. PRUSA has a handy materials guide that is suitable for most non-commercial 3D FDM printers. If you go the commercial printing route the high-temp material selection range is much better.
Filament Material Guide | Prusa Knowledge Base
help.prusa3d.com
Tg is not the right number. Nylon, for example, has a surprisingly low Tg (50-70 celsius!) but can bear significant structural load far above that. There's a goodI was under the impression that PPS-CF would be a good hi-temp filament to print under-cowl parts. After reading this thread its Tg is similar to ABS-CF, so it may not be suitable after all.
I don't think it was PLA, as per the report this had already done 50 hours. Under cowl temps can get very high and ABS doesn't have a particularly high working temp.The AAIB preliminary report says that the glass transition temperature of test samples of the failed part was 52.8C and 54C.
This was PLA and not the CF-ABS the owner was told. PLA should never be used in the engine compartment. It won't even survive in the cockpit in the summer sun.
It appears that Xometry can do HP-MJF Nylon 12 domestically but not internationally. I've been doing SLS Nylon 12, which can be done internationally. I just ordered a part made with HP-MJF and we will see if I can tell the difference.I would not rely on FDM printing for anything aircraft related, but that is just me.
-Chris
I will ammend earlier my statement - I would not rely on FDM parts for anything on my aircraft that is firewall forward, or in an enclosed structure (like buried in a wing). For non-critical items, that are easily inspected as time goes on, it has its place I guess.
FDM gets better all the time, but for ME, that is what I am comfortable with.
Other than being annoyingly intelligent and super friendly - Bill here is a great guy. He really knows the 3-d printing space, and engineering in general, and should be listened to. He has helped me think thru things many times and I always get a better result b/c of his knowledge. Now that he is "out of the closet" please take advantage of his knowledge and skills.After nearly 20 years of lurking I was asked to finally contribute and comment on this. (Hi Mike!). I suppose it's time for me to give back to the community
So:
Yes, there is a 3D printer expert on the forum, he's always listened rather than talked.
Yes, 3D printed parts are appropriate for aircraft
Yes, you can use 3D printed parts fire wall forward. Ive done it for over a decade.
And no, you shouldn't do it if you dont know what you are doing (just like anything)
I've been in the RP, 3D printing, Additive Manufacturing business since 1996. I also happen to own a 3D printer development startup which includes a print service bureau with industrial printers.
3D printing is like any other manufacturing process. Success of any design requires a combination of the right geometry, the right material, the right production process, and sufficient testing. No one would say that sheet metal is not appropriate for aircraft construction after the LCP problems. No one would say sheet metal is not acceptable for aircraft constriction if someone made wing ribs out lead sheet rather than aluminum. 3D printing is just the same. It's just gotten more accessible recently and there is a lot of poor understanding, lack of information, and many, many uninformed opinions floating around.
I'll try to start simply (if not briefly):
FDM printing has materials that work firewall forward and are strong. Here's the biggest problem: When you buy aluminum you are buying to international standards so you know what properties you are getting. There are NO international standards for polymers and that's just for raw pellets. 3D printing filament is even worse. Properties vary all over the map for materials that are sold claiming to be known resin types like ABS, ASA, PC etc. If you are buying internet filament you have no idea what you are getting. Allow me to explain.
When we print layered parts, thermal expansion or shrink that takes place as the part cools will distort your part. When we lay down a layer it will bond to the layer below then shrink. This is like a bi-metal spring where the layers now want to be different sizes. The result is warp, curl and other distortion. There is only 1 definitive solution for this on FDM parts: build the parts at a temperature where those warp forces can anneal out before they add up to enough to ruin the part. This is why production FDM printers build inside a heated oven at controlled temps. This has been well understood since the early 1990s and is very effective. For high performance polymers these warp forces can be enormous and any support structures for overhang are actually designed to stop upward warp rather than downward droop due to gravity.
There are also many forms of mitigation in use but they only work some time. (Very open fills, zig/ zag fills, some fiber filling, heated build plates, low Tg materials, etc.). These have become common place since the explosion of consumer 3D printers on the market that us mortals can afford and for hobby use that is fine. But it is mitigation not a cure. Low Tg materials are the norm here.
The scary thing now is we see "special 3D printing grade formulas" of filament claiming to be specific materials. The special formula is a common base material (like ABS) doped full of plasticizers or impact modifiers. The purpose is to make them print successfully on low temperature or open frame printers and it works. Unfortunately, the thermal and mechanical properties are also affected and sometimes drastically.
Take the recent UK crash. ABS typically has a Tg of 100C - 115C so it needs a printer with oven temp 90C or above. But, this material was tested to have a Tg between 50C and 55C. It was heavily doped material. It gets worse. When we test materials purchased off the internet, we get different properties on different spools or the same part number material. If you are buying "PEI". (polyetherimide) off the internet are sure you know what you are getting?
So what to do? A couple of things.
1) for firewall forward I would not use any material that is not brand name Ultem. It is eye watering expensive as filament ($300/ kg). The pellets alone cost more than $50/kg and it is finicky to turn into accurate filament. Add consistency and traceability and yeah, it adds up. Choose wisely.
2) Do not use an FDM part in an application that requires temp greater than 10 degrees below the build chamber temp that it was printed at. If its stress relieving at 60C in the printer it will always distort at 60C.
3) Dont believe that when you buy filament as something sold as ABS, PEI, PC, etc that you know what you are getting . You do not know what you're getting.
4) Prototype on your home printer than pay a real print shop to make a part for you. Xometery and others are fine. It won't be cheap.
Feel free to ask more.
I apoligize for the length and preachiness of this post. There is a lot to cover and this is just the beginning. I can cover powder based parts in another post. PBF, SLS, HSS, MJF, SAF, etc are all trade names for powder bed fusion parts that have their own can of worms.
It's the Wild West out there. Be careful.
PS: if you find this useful, thank P Howell for poking me into posting.
Thanks @BillTC - I now know a bit more about additive manufacturing. Understanding that "it's more complex than it seems" is very helpful. I predict that in the coming years more and more of our parts will be "printed" and it behooves us to have at least a basic understanding of the process and its limitations. I look forward to more of your posts.Feel free to ask more.
I thank you for your preaching! And I'd love for you to present a deep-dive into powder-based parts.Feel free to ask more.
......... I can cover powder based parts in another post. PBF, SLS, HSS, MJF, SAF, etc are all trade names for powder bed fusion parts that have their own can of worms.........
Im happy to do that but I'm not sure how to make that happen,Bill the Cat -- I think you should do a EAA webinar on 3D printing aircraft parts.
All those words and I never attempted to answer your question.Was reading another thread and had a question. But I don’t want to send someone else’s thread off the rails.
Can't seem to send this as a direct message:Im happy to do that but I'm not sure how to make that happen,
Chris,Can't seem to send this as a direct message:
Hi Bill--
I'm glad to hear you'd be willing. I sent a note to EAA to ask if they'd be interested and how a webinar might happen. They may contact you directly through VAF, or if they get back to me, I'll let you know what they say.
--Chris
