petehowell
Gizmo the wonder dog and I jetted down to see Mom and zip thru the to-do list last night- Mom made Greek Chicken with Orzo and Feta, and it was as good as it sounds. Gizzy might actually smiling as she dreams of Snoopy battling the Red Baron - I'm glad we fared better than Snoopy today.
Somewhere over Wisco on the way home, 9erPopHotel flipped over 2700 hours. That means report time!
Prop overhaul was in this period - but otherwise all was normal. The hot oil came out and the K&P filter was removed and cleaned. The usual carbon was found and a few sparkly flakes, but nothing unusual - the finger screen caught some bigger carbon chunks - none had part numbers.
- Cold Compressions were 72/76/72/77
- 1.5 qts of oil were burned in 52 hours - as usual, all of it in the last 20 hours or so. I noted the oil pressure in cruise was 85psi.
- Valve pics below - still looking pretty good I think!
#1 IN
#1 EX
#2 IN
#2 EX - interesting optical illusion on this one
#3 IN
#3 EX
#4 IN
#4 EX
My setup:
- Crusty 17yr old RV-9A
- ECI O-320
- Carb
- Dual EI
- Hartzell
- Almost all Mogas
- Almost all LOP
- Phillips X/C20W-50
- Borescope is a cheap($11) camera on wire from the orient using the "Cheese" app on an old Linux Mint laptop
#1 IN
#1 EX
#2 IN
#3 IN
#3 EX
#4 IN
#4 EX
My setup:
- ECI O-320
- Carb
- Dual EI
- Hartzell
- Almost all Mogas
- Almost all LOP
