Hi,
I have a nosewheel shake / shimmy that seems to be getting worse despite efforts to reverse it!
Here is a landing video which shows significant vertical shimmy (no horizontal that I can detect). The motion starts basically as the wheel makes contact with the runway, with the worse of it at about 14 seconds in as I am slowing from 25-20 knots.
I have:
- brand new tire
- sent the wheel to Antisplat Aero for the bearing mod, wheel balancing, and shaping of the tire
- torqued the axle and inflated to Antisplat's specs
- replaced the nosegear attach nut / bolt at the engine mount (no detectable wear in the attachment hole)
- breakout force 28lbs
I had a good talk with Al from Antisplat about this and he was not able to shed any new light based on my description. fWhen I received the wheel back from Antisplat, it did get a little better for a while, but now it is getting much worse to the point that the deceleration shimmy is now a front end shudder.
Any advice appreciated!
I have:
- brand new tire
