10 deg. Of flaps in a 6 /6A for take off and for short field take off. How ( for us dummies) do you determine 10 deg. ?
My flaps have stripes (as they become exposed from the trailing edge of the wing), 3" or so long, painted at 0, 10, 20 and 30 degrees. That works great during the day.You can also measure the flap angle and apply tape, paint pen, or permanant marker to the flap to show when the leading edge of the flap extends past the trailing edge of the wing. That'll give you a visual reference.
This is what I did (the sharpie on the flap method), but also use the one one-thousand, two...method as well.You can also measure the flap angle and apply tape, paint pen, or permanant marker to the flap to show when the leading edge of the flap extends past the trailing edge of the wing. That'll give you a visual reference.
Yeah. It ain't rocket science. 12 degrees, 18 degrees? The difference doesn't matter enough to worry about.This is what I did (the sharpie on the flap method), but also use the one one-thousand, two...method as well.
I can agree with causing problems if you forget to retract the flaps. However, if you treat it as a standard operating procedure then you should be consistent enough to make it routine. I had only one experience early after first flight. That was enough for me to ingrain it in my standard operating procedure to make it a permanent part of every takeoff.You can also realize that there’s almost no advantage to using flaps for takeoff on an RV…and you easily may get distracted and overspeed the flaps by failing to retract them in time, given how fast we accelerate. Only if it’s really muddy and soft, do I use flaps…and consider than a special circumstance…
I am aware this post was directed towards Mike’s statement but in reference to your comment about flaps gemerating more drag, well, that amount of drag generated is a dynamic issue. In my post I mentioned my purpose for using flaps is to take off with the “best lift to drag ratio (L/D)”. L/D will give the highest amount of lift you can achieve. You may have less drag with retracted flaps but you will not have the highest level of lift. Drag during take off is not the deciding factor. Lift is however! It is always a compromise. During the take off phase I choose to give up some drag penalty momentarily in order to achieve the maximum amount of lift I can. At take off LIFT is the most important thing to achieve! I want my plane configured to achieve the most of it I can until I leave the surface.Have you ever wondered why the STOL contest guys yank their flaps on at the same moment they rotate, rather than setting them prior to the takeoff run?
The reason is that the drag from the flaps, has to be overcome with thrust…so while you kinda self answered the issue…Yes…it is “easier” to pop the tail up with flaps, the tail will come up almost immediately by pushing further forward on the stick…and all you have to do to get off short is keep the tail low.
Getting off short and great visibility, don’t necessarily go hand in hand.
As for shortest roll…all you are doing by putting 20 degrees of flap, is modify the angle of attack, while adding drag to your takeoff run. I have a rolling wheel for measuring and I’ve done it many times…the shortest distance I get off the ground with 10 gallons in each tank and me…at 600’msl and a 60 degree day…is within thirty feet typically over ten takeoffs…if you measure them you will find sometimes it’s flaps…sometimes no flaps..technique however is very different. You push a lot more earlier and you pull a lot more earlier without flaps…the flaps allow you to be slower and less forceful with the elevator and allow for a lazier rotation.
And to do it right…you have to stop each time and add a bit more gas…to make up for what you used last circuit.
But I haven’t seen them to shorten the takeoff distance. The increased lift, is offset by the increased drag, taking more thrust to overcome the effects…and increasing the time, hence distance.
From my perspective it goes against the grain of simplifying administrative duties at a critical phase of flight. And I don’t buy. For second that doing it as part of your normal procedure makes it better. And as an aside….a constant speed prop is blowing a heck of a lot of air past those inboard sections of flaps…while the relative wind from the airspeed indicator might not exceed the flap speed…the actuator and connecting rods and inboard three feet sure are, so at a minimum, you’re exceeding flap speed on the inboard connections, every time you do it.
Hard to find the good part in this practice when it’s fully considered.
On the other hand, I disagree with your comment about “no advantage to using flaps for takeoff on an RV”. I have used flaps on just about every takeoff for the past 17 years flying my RV. In my initial testing I tested takeoffs with flaps and without. I also do some no flap landings and no flaps takeoffs for proficiency. There is a noticeable difference on my 9A with 180 hp engine and fixed pitch prop when taking off with 10-15 deg of flaps vs no flaps. If the best lift to drag ratio is basically at 10 deg of flaps for most aircraft why would an RV be different? When taking off don’t we always want the most lift we can generate? We want the plane flying as quickly as possible.
Do you think you are generating more lift at the moment of takeoff with using flaps?I am aware this post was directed towards Mike’s statement but in reference to your comment about flaps gemerating more drag, well, that amount of drag generated is a dynamic issue. In my post I mentioned my purpose for using flaps is to take off with the “best lift to drag ratio (L/D)”. L/D will give the highest amount of lift you can achieve. You may have less drag with retracted flaps but you will not have the highest level of lift. Drag during take off is not the deciding factor. Lift is however! It is always a compromise. During the take off phase I choose to give up some drag penalty momentarily in order to achieve the maximum amount of lift I can. At take off LIFT is the most important thing to achieve! I want my plane configured to achieve the most of it I can until I leave the surface.
Live Long and Prosper!
You are saying the OP did not think about using a protractor to measure an angle and that he needed someone on this thread to tell him protractors measure angles?IMHO, Not one of you correctly answered the question of how do you determine 10 degrees. It is measured. I used a digital protractor.
Everyone answered how they set the flaps to 10 degrees such as tape, marks, and counting so 10 degrees can be repeatable OR the merits of using or not using flaps for take off. Not how 10 degrees was determined.
If the question was how do you set the flaps for 10 degrees, then the answers would be correct.![]()
Well many of the canard guys areI've long been Pro-Tractors. Why would anyone be anti-tractor?
What you are doing is generating the exact same coefficient of lift at the point of liftoff, in either configuration…while adding drag coefficient, which has to be undone later…and overcome with thrust. Since you can’t add more thrust…you are hindering acceleration, with drag.
Pretty much every certified aircraft POH that I've seen shows the shortest take off roll is achieved with flaps. Wonder what technique you know that Cessna, Piper, don't?then for real…like I’ve outlined go measure which takeoff roll is shortest. With correct technique, no flaps is shortest.
I agreeI would say that argument is invalid since, with optimum flap, "the moment of takeoff" happens at a lower airspeed since flaps increase the effective angle of attack.
I fly a STOL capable aircraft, not an RV. Almost all my takeoffs start with 10 flap, pull about 30 at rotation, back to 10 for the initial climb out. This is only possible with manual flaps but it gives a significant reduction in takeoff ground roll if timed correctly.
Bob, I appreciate the comment…any airplane with manual flaps can be yanked off the ground a bit shorter with a good yank of the flaps at the moment of rotation.Pretty much every certified aircraft POH that I've seen shows the shortest take off roll is achieved with flaps. Wonder what technique you know that Cessna, Piper, don't?
You can thank Apple’s autocorrect for that one.I've long been Pro-Tractors. Why would anyone be anti-tractor?
