10 deg. Of flaps in a 6 /6A for take off and for short field take off. How ( for us dummies) do you determine 10 deg. ?
My flaps have stripes (as they become exposed from the trailing edge of the wing), 3" or so long, painted at 0, 10, 20 and 30 degrees. That works great during the day.You can also measure the flap angle and apply tape, paint pen, or permanant marker to the flap to show when the leading edge of the flap extends past the trailing edge of the wing. That'll give you a visual reference.
This is what I did (the sharpie on the flap method), but also use the one one-thousand, two...method as well.You can also measure the flap angle and apply tape, paint pen, or permanant marker to the flap to show when the leading edge of the flap extends past the trailing edge of the wing. That'll give you a visual reference.
Yeah. It ain't rocket science. 12 degrees, 18 degrees? The difference doesn't matter enough to worry about.This is what I did (the sharpie on the flap method), but also use the one one-thousand, two...method as well.
I can agree with causing problems if you forget to retract the flaps. However, if you treat it as a standard operating procedure then you should be consistent enough to make it routine. I had only one experience early after first flight. That was enough for me to ingrain it in my standard operating procedure to make it a permanent part of every takeoff.You can also realize that there’s almost no advantage to using flaps for takeoff on an RV…and you easily may get distracted and overspeed the flaps by failing to retract them in time, given how fast we accelerate. Only if it’s really muddy and soft, do I use flaps…and consider than a special circumstance…
