USB extender compatibility with GRT EFIS
Girraf
Friend
I've got 3 GRT EFIS screens on my panel design and intend to bring the USB connection on each one forward to the panel for easier software updating and data downloading. As an alternative to running 3 independent panel mounted USB extensions for data and a separate USB charging device, I found the USB-6A from EI. For $200, it seems like a bargain to get 3 data ports and 2 charging points in a single device. I asked GRT if it would be compatible but they couldn't be sure because the 3 data ports only show 3 wires for each USB extension instead of 4. The Unit is designed to work with the EI CGR-30 Engine displays but I was curious if it could work for data transfer to each GRT screen. Anyone used this before for that purpose?
Here's what GRT had to say:
"it's unusual in that it only shows 3 wires connected in each cable. It looks like they don't connect the ground wires in the cables. A normal USB cable has 4 wires including ground. This may affect the power or data transfer capability."
I read an interesting article a couple of days ago about the problems caused by cheap USB cables. The owner of an iPhone repair shop said they the number of phones that come in with fried electronics increased dramatically after iPhones switched to USB-C for charging.
Most of the time the root cause was the use of cheap cables or cheap chargers.
Cheap chargers yes.
Cheap cables no.
Perhaps he has a load of overpriced Apple cables he is trying to move ?
I have problems with about 10% of cheap usb cables but they have never taken out any of my devices.
I usually lose the cables before they die.
The challenge with USB-C - USB-C cables is that they have many different configurations. There are differences in the amount of power they can deliver, and data speeds that they can support. And other things. Out of curiosity, I bought a USB cable tester, and was surprised by the variations I found in my USB cables.
And often the packaging on the cable does not tell you the truth. 😲
The other challenge is that many devices don't properly implement the USB-C standard, so the charger does not know how much power to supply. This is the case with some of the SkyEcho devices like the SE2. You have to use a "dumb" charger.
For the OP, none of this matters much, since the GRTs are not USB-C.
