Cracked canopy
klong66
Is this reparable? The crack is underlined and goes from the Left side to the Right side just at and under the fairing.
Do you have a parts list for what is needed to rebuild the canopy frame/structure for an RV9A?
Ken
Not very clear to me, but 1st pic (1354) looks repairable. The 2nd pic (1355) is doable assuming the outside fileting (fairing) is removed, as one usually needs access to both sides for a proper repair job.
Using the search tool you will find many threads here dealing with the subject.
As far as the parts list for replacing the canopy, this will be found, as usual, on Van's website. Buying a canopy is one thing (shipping costs are crazy nowadays, you've been warned), but adapting the "glass" to the frame is another. Looks like we're talking about a slider here, so first the big cut would have to be done... talking about a lot of work here... so assuming you can't/don't wanna work on your baby, you'd rather first hunt for somebody willing/able to do the whole works.
Good luck 🍀
Good luck 🍀
This is on a tip up canopy.
That's the first time I've heard of such a big crack in that location - did it suffer an impact or something else that caused it?
Ken
That is a very uncommon crack. Have to wonder if too many and too rigidly attached (like into the ribs) supports were used to hold the front of the canopy down, adding stress when the plexi is moving from expansion/contraction.
