One data point. Ran a Shorai LiFePO4 non BMS in my -8 for about 3 years and 250 hours. It performed excellent. Last fall, I began to notice issues. Long story short, it failed on a local flight. I first noticed a "sweet chemical" smell. Voltage wasn't quite right. Then it snapped - battery. Turned off the alternator field. I was near a field and landed within 2 minutes, shutdown, uncowled as fast as I could. The battery had swolen and pushed the top off the battery case. It wasn't hot or emitting a lot of gas at that time. But I did get it out of the plane with minimal delay. Had I not smelled the gas and kept motoring along, who knows.
Not an EarthX. No BMS. Just a LiFePO4 battery failure. Result - No heat damage, lots of gas, battery case failed. I am back to lead acid as my mission is reliability, not max performance.
I'm sharing this for people to understand what events may happen with an LiFePO4 battery failure. These batteries have unique characteristics and care needed for proper lifetime operation. I still highly recommend this brand. They will sell you a BMS or a non BMS battery (call the distributor). But make sure you know the details of maintaining and operating before installing.
