M macflyer Well Known Member Friend Today at 5:31 AM #1 Anyone running an EarthX inside there 4? I'm thinking about replacing my oddessy inside my my front channel to loose a little weight and more cranking power. Your suggestions appreciated!
T tass Well Known Member Patron Today at 6:24 AM #2 I run the smallest capacity (etx680) and haven’t had any issue. I’ll replace it with the same once it wears out.
Freemasm Well Known Member Patron Today at 7:05 AM #4 Remember you'll need to make provisions for venting (thermal runaway) and BMS status. Neither are a big deal.
Russ McCutcheon Well Known Member Patron 15 minutes ago #5 I installed the vented version of the EathX several years ago in the old -4. One of the best things I've done for the airplane in the past 20 years!
