Bullseye's RV-8 Build
May 28, 2026 - Rethinking My Panel and Electrical System
So I have a cockpit design page (upper left of the nav bar) and I'm using it as a "what's my current plan" page.
I had an update from Sep 21, 2025 that had a panel with most of the switches by the right and left hands (off the panel). Actually, it seems this latest export of my sandbox is labelled 3/11/26.
OBSOLETE, from MAR 11 2026
That looked cool, but recently I got to sit in an actual RV-8 while thinking about reachability and ergonomics.
The bottom line is that two big garmin screens is overkill. I should really do just one. Also, I think the switches at the bottom of the center instrument panel is going to be best, and also alleviates a alot of the right-hand left hand shenanigans.
So, I'm going to start over with the "philosophy essay" that I had saved in the cockpit design page, and then paste what I record here over onto that page again.
Here it goes:
So this post is about 15 years in the making (again). I spent a lot of time dreaming of how I was going to design the RV-7 panel while I was beginning its build, and when I restarted the RV-8 build, I decided to basically copy my previous thoughts and start from there.
To be honest, the copy-paste method works pretty well, my cockpit design philosophy hasn't changed much since I settled on a design back then, except I've noticed a lean towards simplicity.
Instrument Panel Philosophy
Glass panel
The first thing to point out is that I am going to have a glass panel airplane. I cannot find a reason to have vacuum powered steam gauges in my panel when the glass panel technology (and reliability) has advanced the way it has at the price point (approaching the same point as steam) it is reaching. You can get glass for the same price as steam. You can also get BIG GLASS for the price of a whole airplane.
After recently (May 2026) sitting in an actual RV-8, I am back to wanting to have a single PFD (configurable to display engine guages, a PFD, and a map). Also, I'm goign to need an IFR-capable GPS. Most of the “radio stack” boxes should now be built into the PFD suite. I’m currently looking at the Garmin g3x touch system, and the audio panel, NAV/COMs and Transponders are all remotely mounted. Well, shoot. It turns out that there is no remote NAV radio capability with the g3x, so I'd have to either have a separate NAVCOM radio, or use the GTN 650xi, which is almost $20k.)
My emphasis is going to be on a couple of general layout philosophies that will ultimately guide my design. Here they are.
First philosophy: Switches in Order of Use
Looking at my proposed before starting checklist, after I’ve done my preflight, briefed my passenger, gotten both of us squeezed into the seats, and I’m ready to start the engine, I’d like to start from one side of the panel, and make sure every switch is in the down position (there will be a few times when this isn’t appropriate but the “down” check should be standard).
Then, first turn on the battery (engine instrumentation, then set power controls, prime, strobes on (+Nav if it’s night), mags/PMAGS on, then engage the starter, Once the engine has started, check oil pressure, then turn the alternator on. Next, I’ll turn on any remaining equipment, get weather information, clearance, and taxi instructions, then it's time for the taxi light for visibility(night)/recognition(day) on the ground. Next, a runup, set flaps), then just before takeoff, I’ll flip on the landing lights (maybe wig wag, the name for alternating flashing lights), pitot heat (if IFR) and then the fuel pump for takeoff.
Send it!
In the RV-8 (tailwheel) it is prudent to hold the stick all the way back in your lap for start (although some point out this is unnecessary, why not do it?). So, any switch activations prior to start can be with your right hand on the right side of the panel, but any after start should be accessible with the left hand. Some, may need to be activated quickly with your hand on or near the throttle.
One possible switch layout based on that layout:
Before Start (Right (either) hand activation before stick-aft for start):
-Battery/Alternator
-Nav Lights
-Strobes
-Starter enable (assuming the starter is on stick grip)
-Magnetos
Post Start (left hand)
-Avionics
-Lights (Taxi, Landing, Wig-Wag)
-Pitot Heat
-Fuel Pump
I didn't forget about flaps...the flap switch is going to end up on the control stick.
If only it were that easy. This layout, and basic electrical system, has been used for many years on lots of certified airplanes, but why should I stick with a 50-year-old architecture (but Andrew, why change what works!?) when I am building a brand-new, high-tech, all-glass, airplane, right?
Bus Architecture
So, let’s come back to the “no vacuum pump” idea. With the IFR flying I’m going to be doing, I’d rather put a back-up alternator on the vacuum pad where the vacuum pump usually sits. These backup alternators are not belt-driven, but spline-driven, and come in a couple of different sizes. 8-Amp, 20-Amp, 30-Amp.
So how am I going to hook the backup alternator up electrically? Well, I’ve also read a lot about the endurance/essential/emergency bus idea.
The idea behind an e-bus is that when something bad happens to your main alternator (let’s assume for this discussion you only have one), then you can turn off your battery master (a fast way to “load shed”), and use an e-bus to leave on the items that are really required to continue the flight safely. Whether “continue” means “original destination” or “land when practicable” depends on how long your electrical system can support the load you need for continued safe flight and landing. If you have a good battery AND can load-shed enough (if you want this to be part of your emergency actions…some people frown on lots of load shedding actions during an emergency), a battery alone may provide enough power that fuel is now the limiting factor, and not electrons.
Now let’s introduce a backup alternator. With a backup alternator, you could conceivably load-shed below the alternator capacity and continue the flight indefinitely (well, until your fuel runs out).
The nice thing about an e-bus is that it allows quick load-shedding and a dual power path to some “can’t-live-without” goodies in your panel. If you recognize the alternator failure soon enough (annunciations, etc.) then you can load shed via switches. With a single bus, you have lots of load shedding to do. With two buses, you can load shed with a single "bus" switch.
So, let’s look at our options for bus architecture.
Option 1: Single Main Bus.
I can hook up the backup alternator with a regulator that only allows it to flow current if the bus falls below a certain voltage (aka, main alternator dies). All equipment is on the main bus (which means if there is a battery contactor failure, I’m “without paddle,” as they say).
Option 2: E-Bus
I could hook up the essential bus as a true endurance bus; only have the required equipment to continue the flight. The backup alternator could be fed field current from a hot battery bus (or the e-bus) and I could maybe isolate the two busses such that the main alternator is powering the main bus and the backup alternator is powering the essential bus all the time. A bus-tie contactor could be used to tie the two together so if I have a failure on one, I can save electrons until close to landing, then using bus-tie or the failed side’s master to re-energize that bus for all equipment. One of the AEC drawings has the main bus side always powering the endurance bus through a diode, and then an endurance bus alternate feed for when things start going badly. I really like this idea.
An older version of this essay introduced an Avionics Bus here, but I am no longer a fan of this. All my engine monitoring is needed for start. Let’s skip this one. Also, let's skip the two buses with an emergency bus for each of those buses. Too complicated.
WINNNER WINNER, CHICKEN EBUS!
The latest, as of JUN 2026
Go see the page to look at the tables with single and dual failures: https://rv8build.com/2026/05/28/rethinking-my-panel-and-electrical-system/
Let’s summarize in terms of immediate pilot actions.
Single failures: Load shed if the main alt fails. Land as soon as practical if you have smoke in the cockpit (and it’s stopped due to now being on e-bus).
Dual failures: If both of your alternators fail, you’re on your e-bus. Land as soon as practical. If one of your contactor fails AND a diode fails, you’ve lost your failed bus side, but you still have the other bus. Land as soon as practical. If both of your contactors fail, you still have the backup attitude instrument (but not much else). Land as soon as practical.
I think I can live with these failures. Let’s jump back to my sequence.
Ideal Preflight Checks.
I really like the idea of checking everything on the preflight. On a one-bus system with two alternators, I might turn off each alternator in turn to make sure the other alternator picks up the load. I’m thinking about putting all of my essential items PLUS what’s needed for engine start on the E-BUS.
Why?
Because I can climb in the airplane, turn on the e-Bus, and have PFD, GPS (NAV, but no COM2), EMS, Trims, Fuel Pump, Nav Lts, Strobes, Audio Panel, and the Starter (but nothing else, which means the diode is working).
But there are too many high-draw items there!
Well, yes, but also those high draw items are not constant use and could be procedurally prohibited adequately.
Why would I do this? Because I can start the airplane with those, see the aux alt charging the battery, flip on the main bus & Alt, and watch the main alt take over and the rest of the boxes power up. Now flip off the e-Bus contactor and make sure everything stays powered. I’ve now checked both alternators, both contactors, and the diode. No additional electrical checks are required. (Side note, on shutdown, stop the engine, then turn off main bus first, see the e-bus equipment stay powered, then turn off the e-bus.
Switch layouts with Option 2
First turn on the e-bus bus, set power controls, prime, magnetos on, strobes on, hit starter. Once started, check oil pressure, main bus on. Then…lights…blah blah.
Amended switch layout (per first philosophy):
Either Hand (before start)
-E-Bus
-Aux Alt
-Nav & Strobes
-L Magneto
-R Magneto
-Starter (or Starter enable, guarded or keyed)
Left Hand (after start)
-Main Bus
-Main Alt
-Taxi Light
-Landing Light
-Wig Wag
-Pitot Heat
-Fuel Pump
-Flaps
Second Philosophy: Combine switches and groupings
Yikes, those DC power switches sure are physically separated; let’s see what we can do about that…
I think I’d rather have both bus power switches in the same spot.
I don’t want to combine every similar switch possible, but some combinations seem like a good idea. Also, while order of use is importance, I am willing to sacrifice order (a little) to facilitate better groupings of systems. Also, I’m going to combine the Bus and alternator for each side. 4 functions will now be on 2 switches. Also, I’ll only ever want wig-wag on after I’ve turned on the landing or taxi lights.
Third Philosophy: Tactile feedback
This one is a big one for me and my human factors experience during certification flight test. I would like to be able to tell what switch I am grabbing in a dark (or smoke-filled) cockpit. This means that both location and switch type (or feel), along with switch position (up or down…or middle) needs to tell me exactly what that switch does and its current status.
Do I love the perfectly lined up toggle switches that many OEMs use? Of course, but only because it’s aesthetically pleasing.
I’m okay with a group of similar toggles, as long as it is obvious. The easy ones jump out. AEC has convinced me to use DP3T toggles for the master switches. Locking versions are big and obvious. Ignition (PMAG) switches will also be locking three-position toggles. (OFF - TEST - ON). But all four of these switches aren't touched in flight.
Lighting switches will all be regular non-locking toggles (NAV, STROBE, TAXI, LDG (and Wig Wag). I think I'm going to keep the NAV/STROBE switches away from the TAXI/LDG switches. It'll give good separation of the locking toggles for the DC switches and the PMAG switches.
Let’s take another look at the layout with switch types:
Group labelSwitchSwitch Type
DC POWERMain Bus MasterLocking DP3T Toggle (2TL1-10A)
DC POWEREBUS MasterLocking DP3T Toggle (2TL1-10A)
RECOGNITIONNAV LTSDP2T
RECOGNITIONSTROBE LTSDP2T
IGNITIONL PMAGLocking DP3T Toggle (2TL1-10P)
IGNITIONR PMAGLocking DP3T Toggle (2TL1-10P)
START ENABLEStart EnableCovered SPDT toggle
LIGHTINGTaxi LightDP2T
LIGHTINGLanding Wig WagDP2T or DP3T
ANTI-ICEPitot HeatDP2T
FUELFuel PumpDP2T
I think this gives me some good separation between similar switch types, and I’ll prevent almost all inadvertent switch operation.
Back to flow…the nice thing is that on climbout, while transitioning to cruise, I will be using these switches in opposite order. fuel pump off, pitot heat off (after I’m through the theoretical cloud layer I had to penetrate on takeoff), landing and taxi lights off when transitioning to enroute climb.
The lights and pitot heat, fuel pump combination is a lot of toggles next to each other. I might put the fuel pump waaayyy left, closer to the throttle.
Fourth Philosophy: Normal Operation, switches all up.
The background for this is really a flow check. I want to look down just before takeoff, scan across the panels with either my eyes or my fingers, and have the airplane ready for takeoff with all switches up. (Pitot heat won’t always be needed, but barring any temperature limitations for pitot heat, I won’t be WRONG to have it on for takeoff, especially if it's the regulated probe from Garmin.)
Okay, we’re done! Oh wait, what about the “other” switches (Gulp!)
OTHER SWITCHES
Using the above logic and reasoning, I’ve also adding some items to the panel.
These items include:
-Smoke System (with LED indicated “pump on”)
-Copilot stick switches enable
-Interior light dimmers
-12V power (maybe USB power, maybe both)
-Eyeball vents
-Cabin heat Knob
-Seat heat switches
Group LabelSwitchSwitch Type
SMOKESmoke On LEDIndicator LED (Blue?)
Smoke switchSPDT Toggle (with stick switch)
COPILOTCopilot Stick Switches EnableSPDT Toggle
INTERIOR LIGHTSInstruments DimmerDimmer
Panel lights DimmerDimmer
Courtesy DimmerDimmer
DC Power12V or USB power (maybe switched?)12V power jack, right side
Eyeball ventN/AVent, left side only
Pilot Cabin HeatN/APush pull knob, lower right
Pilot/copilot seat heatN/AToggle
The remote setting on the smoke switch will allow a stick-mounted switch to operate smoke. This will be an “enable” switch on the panel, and a push-ON-push-OFF switch on the stick.
The courtesy light dimmer will be on the hot battery bus and will power the footwell and baggage areas. I want to be able to walk up to the plane and turn these on to load baggage and get in the airplane without turning on the master.
Eyeball vent (fresh air), Cabin Heat and Seat Heat for each seat will be on the outer edges of the instrument panel.
STICK-MOUNTED SWITCHES
Looking at Stick switches, I blatantly stole this from Infinity Aerospace:
Typical Stick Grip Switch Combinations for Aircraft WITH Electric Flaps AND Autopilot:
-(thumb operated 4-way switch via China Hat) — Pitch and Roll Trim
-(index finger) — Push-to-talk
-(top – thumb side) — Flaps – (ON)/OFF/(ON).
-(half way down, thumb side) — Auto Pilot Disconnect (Normally Open push-button (8632 N.O.))
-(pinky switch) — Smoke ON.
-(top – knuckle side) — Engine Start Normally Open (8632 N.O.) push-button
Layout:
So where do we put these switches? Originally, I was thinking about a dual-giant-display layout. That looked cool, but recently I got to sit in an actual RV-8 while thinking about reachability and ergonomics.
So now I'm back to this single-display scheme, with all the switches along the bottom edge.
I'm POSITIVE I won't change my mind again.
May 30, 2026 - Benchtop Electrical System/
As a continuation of my last post, I decided to buy some parts and start experimenting with actual electrons.
But first, I wanted to draw up my schematic in a way that's presentable.
Here's the latest schematic based on my latest "option 2" split bus architecture concept.
June 03 2026 Schematic
Lots to talk about here, but basically (and quoted from my last post):
I’m thinking about putting all of my essential items PLUS what’s needed for engine start on the E-BUS. I can climb in the airplane, turn on the e-Bus, and have PFD, GPS (NAV1 & COM 1), EMS, Trims, Fuel Pump, Nav Lts, Strobes, Audio Panel, and the Starter (but observe that other items are not powered, which means the diode is working).
With that settled (ha! it'll change multiple times, I'm sure), I ordered some parts.
  • 30A power supply - Amazon
  • Contactors
  • Diode
  • Two Fuse blocks
  • Ground bar - Lowes, just for this mockup
  • Wire
  • Fast-on connectors
  • and a bunch of switches
I'm still waiting on two locking switches for the ignitions
The cool thing is when I flip the EBUS switch, the ebus comes on. When I flip the main bus switch, BOTH busses come on (as designed).
I would like to get these components mounted to a 2'x2' plywood board so it can stay intact and move around the shop. Back to Lowes.
This was a fun departure from aluminum, but I'm ready for that dang wing kit to arrive.
1.5 hours.
As I mentioned in Wing Stands Part One, I've done this before here and here, so I had the general idea of what I want to do, but I'm thinking about some updates.
Here's a shot of what I had before and my sketchup model of what I'm going for this time:
I think this picture was from December 30th, 2010.
That's the dream (but with smoother wings, of course.)
Today, I had $100 burning a hole in my pocket (no I didn't) so I decided to grab some lumber and some locking 4 in. casters from the aviation aisle of my local big box store and whip up some wing stands.
I ended up sticking pretty close to my original plans, except I doubled up the long braces along the bottom.
An in-process pic, before I started sweating too much.
After repeating that first corner three more times, flipping the assembly over, attaching my locking 4-in casters, I flipped it back over.
It's bigger than I remember.
I had previously made the supports, so all I had to do was measure and drill some pilot holes for the 5/16" lag bolts I used.
Here are the support from part one:
Throwback!
A closeup for you, once attached.
a work of art!
And here are all four.
4 adjustable supports attached.
I'm not yet done with the stand. Each of the supports is going to get a small triangular support near its base to stop any north-south and east-west movement. The pre-punched RV-8 wings will provide stability once they are attached, but I'm not happy with the flex in the system yet. a few supports will stiffen that right up. 1.5 hours today.
June 8, 2026 - FlyLEDs Part One
Still no word back from Vans on the wing arrival timeline yet.
BUT, the FlyLEDs box arrived! All the way from Australia!
The box is smaller than I thought, but a lot of stuff in this hobby is dollar-dense.
Goodies inside.
After unpacking (I got the "Works" kit), I was left with a ton of parts to start to put together.
Here's everything from the box.
There are a ton of instructions online, which I've archived in the following files for some future builder in case the site goes down.
The-Works-1-Wings-June-24
The-Works-2-Controller-June-24
The-Works-3-Lighting-Assembly-June-24
The-Works-4-System-Installation-June-24
The first step is to solder the white LEDs (covered in blue plastic in this picture) is the first step.
The left and right wings' forward and outboard plates.
The next few steps attach the individual red and green LEDs around the landing/taxi light openings and the white LEDs, then to attach the green connectors and the large resistors.
It's a bad picture because you can't see the back side, but there are a ton of soldered components.
the boards are done!
Next up, the controller board. Here's the blank controller board.
Ready for solder.
And here's the final board with all the resistors, LEDs, microcontroller, DIP switches, capacitors, DB15 connector, and terminal for the landing lights.
Now how to store it?
The last step of the part 2 of the instructions is to test with a 9-volt battery.
It works!
Now how to store it? the FlyLEDs Website says this:
Another customer (thanks Dick!) has tweaked the files to separate the base from the lid. He presents two versions of the lid, one with the LEDs elevated from the PCB and one with the LEDs mounted flush to the PCB as per the plans. <a href="https://flyleds.com/wp-content/uploads/2022/09/The-Works-box-v2-Dick-Tasker-.zip">Click HERE</a> for the STL files.
I then googled who can print me a box from the stl files and ended up ordering from <a href="https://craftcloud3d.com/">Craftcloud® | Streamlined Service for 3D Printing &amp; CNC Machining</a>.
I uploaded the two files and sent ~$25 and they should be here in a few weeks.
2.5 really fun hours today.
Throwback!
a work of art!
Small comment. You will ideally be standing in the middle riveting that side of the wings during the build. The gap you will have between the two wings seems a little tight ... (tho you may be smaller than me !)
I spaced them the same a little wider than I did on my RV-7 kit. It was tight then, I'm hoping I gave myself a little extra room...
