Seeking advice RV3 annual condition inspection
Richard RG
Tragically, another RV3a has recently gone down. Though my RV3 is the B model having the structural upgrades to address past wing failures, seek advice from those that have built and those that know way more than me, where best to inspect with both mirror and boroscope for potential cracking or fail points.
The plane is currently undergoing its annual condition inspection, all of Vans published service bulletins have been complied with and are reviewed prior to each inspection. Any advice regarding enhancing the thoroughness of my inspections would be much appreciated, thanks in advance!
Since the “B” wing is completely different from the original (and the original that was modified to “A” status…), you dont’ really have to worry about an “A” wing failure occurring in the “B” wing spar. The “B” wing is really a miniature version of wings designed for the -7 and -8.
The thing most folks don’t think about is that inflight breakups (of all aircraft, not just RV’s) usually start when the tail fails or comes off. The loss of the tail leads to an immediate pitch down, causing wings to fail in the negative-G direction (this is the classic “pulled the wings off in a thunderstorm” mishap). If you have a “B” wing, I woulnd’t worry about the wing suddenly and unexpectedly failing on you all by itself - I’d look at how well your tail is designed and built - but more importantly, how it is attached. The original RV-4 horizontal stab forward spar looks really wimpy to those of us used to the later designs - even the RV-3 has been upgraded to the newer structure. But the attachment depends on those two forward spar attach bolts being drilled perfectly to the longerons, the rear bolts properly drilled, and the forward spar-to-root ribs being free of cracks (or being re-inforced).
So if I were worried about structural failure, and what you can inspect for, I’d concentrate on the tail…and that is exactly what I do when performing condition inspections on our birds and when I do DAR inspections on others.
The thing most folks don’t think about is that inflight breakups (of all aircraft, not just RV’s) usually start when the tail fails or comes off. The loss of the tail leads to an immediate pitch down, causing wings to fail in the negative-G direction (this is the classic “pulled the wings off in a thunderstorm mishap). If you have a “B” wing, I woulnd’t worry about the wing suddenly and unexpectedly failing on you all by itself - I’d look at how well your tail is designed and built - but more importantly, how it is attached. The original RV-4 horizontal stab forward spar looks really wimpy to those of us used to the later designs - even the RV-3 has been upgraded to the newer structure. But the attachment depends on those two forward spar attach bolts being drilled perfectly to the longerons, the rear bolts properly drilled, and the forward spar-to-root ribs being free of cracks (or being re-inforced).
I believe this to be the most useful piece of information I have yet read on this site. Thank you.
--Ron
If we're going to use this thread to cover RV-3 wing (spar) modifications could we have the OP change the thread title to something like "Pre-RV-3B condition inspection advice"?
Again there is no "B" modification.
As mentioned earlier, an RV-3B has completely different wing spars compared to the original RV-3 and compared to any modifications ("A") made to the original spars and wings.
I looked at Van's website and there is no mention of the Change Notices (CN-1 and CN-2) that were issued back in the late 90ies. If there is interest I can scan my paper copies of the change notices and post here so that pre-RV-3B owners can inspect their RV-3s to see if/how they were done. (CN-301 TYPE I, CN2-I SPAR CHANGE).
EDIT: There are a lot of printed pages, so I'll only do it if someone wants the whole RV-3 wing (spar) history and the instructions with pictures for performing the CN2-I ("A") modifications.
Finn
Finn
This would be appreciated. Out of prudence I belive this is the responsible way forward. I would like to inspect my -3A before next flight.
In addition to what Paul has mentioned about tail attach points.
Confirm that the rear spar bolt hole does not have less than the min. edge margin distance.
Regarding the tail attach points, can you show the build diagram or reference the page number? This would be for the 3B, the latest plans.
The RV-3B primarily had a redesigned wing, the rest, fuselage, tail etc. was mostly not changed it seems from the mid 1980 up.
Try page 26. assembly tail drawing
this will show attachment fasteners, location Al. angle and doubler plate callout.
Also check Van's SB for the RV-3, tail group.
mg
I would appreciate this tremendously!
Looks like David Paule beat me to it:
Man I really appreciate your input and knowledge of these matters. Thanks and I wonder if there is any kind of list of shops that really know there stuff about these aircraft. Somewhere you could call and schedule a real detail inspection of your airplane that you purchased.
Thanks again!
Any chance of posting pictures of where to look and more detail on “edge margin distance” what ever that means!
Isn't that covered in Section 5 of the builder manual?
For any hole, but especially for the bolt attaching the wing rear spar to the fuselage, you need at least 2 times the bolt diameter to the nearest material edge.
For a 5/16" bolt that's 5/8" from center of bolt hole to the nearest material edge. In attempts to make wing leading edges square and aligned, a builder may have been tempted to move wings out more than allowed before drilling that critical hole. Or in attempts to set wing incidence, move rear spar up or down more than allowed for the edge distance, before drilling that hole. Or simply drilled the hole closer to material edges than 2 x bolt diameter.
Of course where plenty of material were available we would choose hole center location that were furthest from edges of both materials to be bolted together, thus increasing the margin.
I am going through my first conditional inspection on my -4. Thanks for posting. I have printed this and will keep in my conditional inspection checklist.
Hello Paul.
Please clarify the ‘original RV-4’. Based on year of kit, specific spar or parts or something else ?
Thanks !
Thank you all for the feedback regarding my request for annual condition inspection advice for the RV3b. I've edited my thread title to a more generic request for advice pertaining to inspection of RV3's in general.
Thank you Paul, for highlighting the importance of a detailed inspection of the tail assembly and during my inspection will note edge distance margins of spar bolts.
Hopefully others can add to this thread with specific inspection advice for the pre RV3b wing.
Hello Paul.
Thanks !
I have never had or built a -4, but have looked at them now and again. The original Harmon Rocket II used the -4 tail, and I have seen them there as well. If you have a -4 (or any RV), you should have the drawings - if you don;t you can register on Van’s web store and then you’ll have direct access to all teh drawings for your model. I never look at the paper plans for my RV’s anymore - I just grab what I need on the web.
I can’t tell you when (in years) changes have come along, but the original design basically had the forward spar webs continuing inboard of the root ribs to the centrlien of the aircraft. Then there is a splice plate that joins the two of them and the front sppar of the vertical stab. All these parts were sheet metal. In later RV’s, aluminum angles (two of them, one tp, one bottom) were added, with “fingers” that extend outboard of the root rib to actually transfer loads from the stabilizer surfaces into the center section and then to the fuselage longerons. the original design just has one angle riveted to the bottom of the center section (no extension outboard of the root ribs) and bolted to the longerons. One look at a modern RV will tell you instantly how much beefier it is.
Get the drawings for your ship if you don’t have them! For those over you interesetd in the edge distance/longeron drilling, the drawings show that detail as well. If you’re not familiar with it (because you bought the plane), you should definitely study up on how the tail is attached if you’re going to be inspecting it (with your LSRM or A&P license).
Paul
Probably what keeps Van and Van's Aircraft folks up at night (and their lawyers). Not the RV-3 specifically, but builders thinking they are ‘engineers’ and doing dumb stuff.
Definitely read the above. It gives a very good history summary of the CN1 and CN2. I did not remember that FAA had prohibited aerobatic flight without CN1 (strengthening wing root rib and rear spar attachment point), even though I had done both plus CN2 on my RV-3A back in 1999.
Just read this post: https://vansairforce.net/threads/rv-3a-n696db-inflight-breakup-june-15-2026.244242/#post-1940376.
In connection with https://aviation-safety.net/wikibase/196180 I'm now thinking that pre-RV-3B annual condition inspectors need to learn to look for signs of over stressing -- signs of buckling of upper wing spar cap. Appears that ultimate failure may not be the direct result of a one-event over-stressing but perhaps a cumulative effect that then results in wing failure at relatively benign low-G maneuvers.
So what are the signs of buckling or over stressing we need to look for?
Bucking is a completely elastic behavior. But sometimes at the edges of it, there will be some evidence of yielded material, such as a bend that shouldn't be there, left behind when the body of the material buckled and locally yielded around the edges.
Dave
I had an RV3A (had both wing mods) from 2001 to 2008 and put 500hrs on it. I didn’t build it or do the mods but was very concerned about the reputation of the -3 and so I reviewed the drawings and the modification paperwork and read all the accident reports and had experienced A&Ps inspect the airplane but there was always that question in my mind about how strong and safe it was. _I decided not to learn and become a fledgling aerobatic pilot in that airplane_. There is a huge difference between someone that is really good and smooth and the rest of us. Now, 20 yrs later I’m an A&P and have built my own airplane and am 20 yrs smarter. I haven’t stopped taking risks however. Here’s a pic of the tail on the airplane I built and tails don’t get much stronger than this. Now, instead of being concerned about the tail or the wings I worry about the about the prop or engine failing bc I’m spinning it up so high and we don’t know what we don’t know. This is experimental aviation after all. Do what you can, keep learning, keep inspecting, don’t do stupid things and then forget about it and strap in and go have fun.
Perhaps another thing to look at: Were the mods done before first flight? If the mods were done after first flight, how many hours and what kind of stresses did the airplane see during those pre-mod hours?
On the rear spar attachment point, would it be damaging to tap that bolt out and inspect for oblong or enlarged holes as sign of excess stress there? (At least once for new owners or inspectors of an old RV-3).
Just food for thought. Not really an issue for me. I need to look at the tail attachments on both my RV-3B and RV-4.
Tail attachment point(s), per the current RV 3B drawings I received last month. Looks like the main change was in 1987, with some comments/depictions up to 2003.
Has anyone beefed-up the attachments for the tail? Unnecessary? However, like many builds, details are important with attention on the bolt spacing, type, etc. Good thread on the RV 3B with VNE and flutter:
https://vansairforce.net/threads/rv-3b-vne-empennage.193751/
I guess with the RV-3 it's mostly checking hole edge clearance. With a 1/8" thick 3/4x3/4"angle there isn't much tolerance in placing a hole for an AN3 bolt.
It’s the same for most RVs.
Took me 4 weeks of measuring, re measuring, and drilling to get those holes right. I still look at the whole attachment assembly and think “is that it?!!”
There was a thread on here a few years ago where a guy had bought a built RV and the forward HS attachment bolts didn’t go through the longeron. Buyer beware I suppose!
