I have a Lycoming IO-360-B1F (180 hp) in my -8 and I’m noticing brief micro-surging at idle during taxi. The issue only occurs when the engine is hot. Cold starts and initial taxi/idle are normal. I tried using the electric fuel pump while taxiing to see if it would help with fuel vapor or pressure, but it didn’t make a noticeable difference. Mixture adjustments on the ground also don’t seem to significantly affect it.
CHTs are normal. I currently only have one EGT probe installed, so I don’t have full cylinder comparison data. I’ve had a small induction leak before on an O-360, but that case didn’t present with this same surging behavior, so I’m not sure if that’s likely here. A local pilot also commented that the idle sounded slightly unstable while taxiing.
Any ideas on likely causes, such as induction leak, idle mixture setting, fuel servo behavior, or vapor-related issues?
-Ian
-Ian
