I got asked how I wanted the engine inhibited after the runs were done on the test truck. The runs will be done with aero shell 100 (red band).
Having read over Lycoming service letter 180b specifically:
“An alternative method is the use of Cortec VC1-326 preservative concentrate added to the original oil at a ratio of 1 part VC1-326 to 10 parts of oil.”
I assume they mean this additive. (The name is slightly different).
This is vastly cheaper than the original method in the lycoming letter (corrosion additive mixed with aeroshell 100 oil / nox rust). Aka the Tanis kit.
I was wondering if the additive was fine to add to the break in oil? The service letter doesn’t specify the type of oil.
I would then mix some extra up and spray it into the cylinders also (it calls for 2oz per cylinder, or about 60ml). Can you even spray aeroshell 100? (Maybe it needs to be hot to spray?)
Then desiccant bags in the 2 exhaust pipes and one in the throttle body, plus desiccant plugs.
Do the desiccant bags need to be the fancy ones from spruce, or Amazon is the same thing?
