WingsForWillem
I'm New Here
Hey all, I recently bought an RV-6 and I’ve been absolutely loving it. However, I ran into an issue with the lighting/ADS-B setup that’s keeping it from being night legal.
Right now, the aircraft has a right wingtip position light both for the wing and the rear position light, and a strobe.
The right wing is set up normally and works fine.
The left wing originally had the same setup, but at some point it was replaced with a uAvionix skyBeacon, which only provides the strobe and wing position light functions. Not the rear position light.
This RV does not have a dedicated tail position light because the original wingtip nav light arrangement was intended to satisfy the visibility requirements. The issue now is that with the skyBeacon setup on only one side, the lighting coverage/visibility from that side no longer seems compliant for night operations.
I want to make the airplane night legal again, so my plan is probably to replace both wingtip lights anyway since the remaining conventional nav/strobe on the opposite wing is very dated and currently intermittently working.
Here’s where I’m confused:
From what I’ve researched, the Trig TT22 is ADS-B Out capable as long as it’s connected to an approved WAAS GPS source. The airplane already has a Garmin GNS 430W, so I’m curious why the ADS-B Out wasn’t configured through the TT22 in the first place, since I know a lot of people run that exact combo successfully.
So my main question is:
Is it generally a straightforward process for an avionics shop to reconfigure the TT22 to use the 430W as its GPS source for ADS-B Out? Or is there more involved than I’m thinking?
I’d definitely have a shop handle the work, but this seems like the cleanest solution so I can ditch the skyBeacon and go back to a normal matched wingtip lighting setup.
Curious what you guys think or if anyone has dealt with a similar setup before.
Thanks!
Thanks!
