So I have a co-pilot stick enable switch but it isn't working like I expect it to. I ran a wire from the switch (WHT/BLK) to the factory co-pilot stick grounding location (shown below).
The problem is the stick is enabled regardless of the switch position. I tried swapping the BLK ground wire with the WHT/BLK co-pilot stick ground wire. No change. Thoughts????
This image from the RV-14 plans shows the location of the pilot control stick ground but the co-pilot stick has a ground as well.
