enigmakv
I have a small slow leak somewhere in my left fuel tank. The original owner/builder had already pulled the tank off to try to patch it once so at least the paint has already been cut.
I have spent quite a bit of time researching the plans and online to figure out how to remove the tank and am getting close.
On the back of the spar are EIGHTEEN (18) fasteners (3 ea in six locations). I eventually had to disconnect the aileron push rod on the inboard side to get just enough access to the heads of the fasteners while reaching my big hands up through the inspection panels. My arms are cut, my knuckles bleeding but at least I got those bolts out. At least one set of three are between two closely spaced wing structures. All but six of the bolts were very hard to reach and had to be done blindly. Several of the bolts were located such that I could only turn one face at a time due to the wrench contacting internal structures.
My question is, for any of you who have pulled a tank after full assembly/painting, how the F do you reattach the tank at all of those blind/restricted locations?
