My RV8 (bought not built) has a slightly heavy right wing- (about 3 gallons worth which Vans considers minor). But there's a few other factors at play- the right wing, everything lines up nicely- Flap is UP (measured by straightedge on bottom of wing), aileron clamped to flap, aileron aligned with wingtip.
But the left side, the flap is a bit low (measured by straightedge on the bottom of the wing), the aileron outboard edge appears a bit high, and the wingtip doesn't match perfectly.
In flight, the ailerons find their equilibrium and are not symmetrical to the flaps or wingtip. They are displaced a little to the left- i.e. holding up the right wing. All of this while I'm holding a tiny bit of right rudder, maybe 1/2 a ball in cruise. There are no trim tabs installed on any control surface.
I've read about 10 threads on this- so my first inclination is to try raising the left flap (might require bending the inboard lower skin of the flap- right now it sits flush against the belly skin). Then see where we are at. Maybe I can then lower the left aileron and finally see about matching up the wingtip?
I would have loved to talk to the builder about this stuff, but an online search shows he passed back in November.
While it's not a show plane, it's quite well built and so far everything I have seen is to plans. So I'm guessing this current setup is not an accident, he may have raised the left aileron for a reason. I have not measured the angle of incidence or the sweep, maybe I'll get some plumb bobs and do this first?
Also being a novice, I don't want to screw up a good flying airplane, but I am a perfectionist so there's that. There's always some more projects I can tackle to make it mine- so maybe I should fly on and push this a little further down the list?
Right Flap:
Left Flap:
Right Flap:
Left Flap:
