AntiSplat EZ Cool Cowl Flap — Brazil Testing and 4-Flap Configuration on RV-10 IO-540
50Pesos
I recently spoke directly with Al at AntiSplat and he mentioned that significant testing was done in Brazil with the EZ Cool cowl flaps on RV-10s with IO-540 engines. The results apparently showed that side placement at 3 and 9 o’clock outperforms bottom placement on the RV-10 specifically, and that a 4-flap configuration — sides plus two on the upper cowl just forward of the firewall — produced the best overall results for the IO-540 heat load.
I’m building a custom fiberglass cowl on my RV-10 with a Barrett IO-540-D4A5 at 300 HP, 9:1 compression, cold air induction. I have a hard fiberglass plenum top, twin tunnel exit geometry, and I’m instrumenting with piccolo tubes for the first flight program.
I’m looking to size my fixed cruise exit area correctly and determine whether to provision for 2 or 4 flap locations before the cowl is finalized.
A few specific questions for anyone who has done this testing or spoken with Al about it:
1. What inlet and exit areas were the test aircraft running when the 4-flap configuration was evaluated?
2. What was the measured CHT improvement with 4 flaps versus 2 on the IO-540?
3. Did the top flap placement — just forward of the firewall — open inward into the plenum or outward through the upper cowl surface?
4. Was the fixed exit area reduced as part of the test program, or were the flaps added to a stock exit?
5. Any data on cruise speed penalty with all 4 flaps open versus closed?
I understand this may be proprietary to Al’s testing program, but if anyone has firsthand knowledge or has had a similar conversation with him I’d appreciate hearing what you know. I’m not looking to reinvent the wheel — just trying to make informed decisions before fiberglass sets.
Just a data point, but I have a 9:1 CAI with a plenum and live in a hot country and have no cooling issues. No cowl flaps.
I had inlet rings machined up to fit the ID of the Showplanes cowl. Exit is the SP standard double tunnel.
I can measure the inlet and outlet areas for you next time I’m at the hangar.
I could maybe see how one or two flaps may help - maybe with oil temp if you intend to spend a lot of time down low and slow in summer- but 4 seems like gross overkill to me. Were the Brazilians doing turbos?
I believe I can answer no. 3 from a conversation a couple of years ago with Alan:
The top cowl flaps open upward with the exit facing aft. I'm curious if the warm air exiting from the upper flaps would warm the fwd canopy and act as an external canopy defog.
EDIT: I have piston oil squirters on my PV IO-540. My cooling challenge was oil temps.
Good Luck!!!
Showplanes cowling also and no cowl flaps. Stock IO540 with 8:1 compression and WW300 prop. One operational input I do is close the oil cooler door at departure. (And yellow alarm is set at 195 F) This seems to really help CHT's even in Florida and don't need to open it till 3,000 - 4,000 ft. I also cruise climb (120 - 130 knots) at 22 MP by 2,400 RPM to 24 squared. CHT's never go over 400 F or if so barely. Cowl flaps seem just a point of drag which also negatively effects cooling. I also pull back to 65% HP at ~ 4,000 ft and go LOP early which help CHT's and OT.
To be honest, I don’t know if they were using turbos. This is all the information I have so far. That’s why I was hoping somebody from down south would be chiming in to enlighten us all.
Good Luck!!!
I have oil squirter too. I thought when building the engine upsizing the duct and the oil cooler was gonna take care of it all. My previous cowl I had it under control finally but there was an education to get there
