Check out the link below. It is a huge thread, 24 pages long, dating back to March 2016 when the 660 first came out. It contains an encyclopedia of info about the 660. Good luck.
http://www.vansairforce.com/community/showthread.php?t=135203&highlight=Aera+660&page=24
I was going to purchase a 660 when it first came out but didn't because it could not display XM weather like my current 496.
Has XM weather capability been added?
Ok, after a few problems, finally have data bases downloaded and inputted.
Second, found that despite the Garmin site saying the download interface software was compatible with XP SP3, turns out it didn't work for me. Switched to Win 7 and it worked.
Was a bit confusing if the interface software downloaded and installed properly or not. Did it again with another call to Garmin (wait time 1 minute- bravo again!)
Steve, I recall when I got mine I couldn't do this, and my recollection was that I had to update the firmware to a certain level before it would let me. That required a hard connection to my Windows PC to get started.You probably have your reasons for not using the Aera 660 built-in Wifi to download databases and software, but for the benefit of others we wanted to mention this capability.
I have been flying with an Aera 660 longer than anyone, and I have never actually downloaded databases with anything but Wifi.
Now that it's updated though, everything comes in on WiFi as you say... Much more convenient than the old way!
Ah, yes, now that you say the version numbers I recall that's exactly what happened on mine. It was just the software I needed the computer for (once).The Aera 660 has always been able to download databases over WiFi. Software downloads over WiFi have been supported since V2.60. You are correct that anyone having software older than V2.60 will have to perform a one-time upgrade using a computer, and then software updates will be semi-automatic over WiFi (when available) after that.
If it was purchased in Aug 2016 it would likely have been built months before that at Garmin... Lead times for consumer electronics can be remarkably long.rv6ejguy said:Think my unit was Aug. 2016 and had V 2.5.
Remarkable!Just purchased this month but had a much older firmware version installed.
Appreciate the suggestion and will check it out. Since it's bigger, the deal breaker could be that it might not fit in the same panel spot where the 496 currently is (with its AirGizmos dock).If you've been using an iPad and looking to change to a 660, may I suggest a 760. Same as the 660 but bigger screen and I believe 1 to 2 years newer. It is more expensive but the screen is very nice. I know several people, including myself, who have the 660 and 760s and both are really great for the money.
Airgizmo dock for the 660 is exactly the same form factor as the 496. So it will install in the exact same place that the 496 occupied. Coupled with an old gdl39 or the newer gdl50 or gdl52 you will get full weather and traffic.Appreciate the suggestion and will check it out. Since it's bigger, the deal breaker could be that it might not fit in the same panel spot where the 496 currently is (with its AirGizmos dock).
Still very relevant IMO. I have two 660s in my -8. 760 is bigger, but 660 works very well in my case.Since this is a VERY old thread - not sure anyone will see this...
Currently use ipad mini with FlyQ (Foreflight competitor) as my primary VFR NAV device with an old panel-mounted Garmin 496 (via AirGizmos dock) as my backup. On a recent XC my ipad malfunctioned while navigating near Class B. The 496 was very difficult to see in the sunlight causing me some unwanted elevated stress. So I'm thinking of swapping the 496 for the Garmin aero 660 but have some questions:
1) I know it's been around for about 10 years but still see it for sale at Spruce and Sportys - but is it still a good choice?
2) I'm reading conflicting info on cost of updates. Some say it's $149/year and others say that is per update - which could be nearly monthly. Which is it?
3) Would love to have traffic but not mandatory - but is it even an option? (My ipad connects to my Stratus).
All insights/suggestions appreciated!
I'd hoped (naively) that the Aera 660 would work with my existing Stratus ADS unit - but learned today that I'd have to buy a $900 GDL50 if I wanted traffic and weather on the 660. Since my current panel mounted 469 is my backup (ipad/FlyQ is primary), I'm rethinking the idea of upgrading it to a 660. If do upgrade it, I will likely not pop for the GDL50.Airgizmo dock for the 660 is exactly the same form factor as the 496. So it will install in the exact same place that the 496 occupied. Coupled with an old gdl39 or the newer gdl50 or gdl52 you will get full weather and traffic.
I use a RAM ball mount for my ipad mine and have used a yoke mount in a Piper - but have never seen or heard of a RAM mount that attached to the contol stick. Can you provide a link or the product name? My quick search comes up with adhesive (i.e. sticky) mounts.I bought a 660 in December for my RV-4. No room on the panel so I bought a RAM mount for the stick. Given the limited space this seems like the best mounting option. I also bought a GDL50 and upgraded the com radio with a GTR205. I hardwired the GDL50 and GTR205 to the 660 serial ports. I like that I can push com frequencies from the 660 to the GTR205.
Thanks for the links! That's a mounting option I'd never considered! Obviously, you are able to use it without it obstructing the stick movement - do you mount it to the left seat stick or the right seat stick to ensure full range of movement?I bought this mount for the stick from Amazon
https://www.amazon.com/dp/B0989PNG3C
I have an RV-4 so it's mounted to the front stick. I set the map orientation to portrait to maximize the side clearance between my legs. I can snap a picture of the setup tomorrow. There's just enough room to get full motion but of course in normal maneuvers the stick hardly moves at all.Thanks for the links! That's a mounting option I'd never considered! Obviously, you are able to use it without it obstructing the stick movement - do you mount it to the left seat stick or the right seat stick to ensure full range of movement?
Thanks for posting the pictures - very innovative solution to limited display space!Here is my RV-4 stick mounted 660. Not as convenient as on the panel but given the limited space it'll do.
It all worked out when I realized that little square block with the ball is a perfect fit for the Garmin 660 cradle.Thanks for posting the pictures - very innovative solution to limited display space!
Thanks for the insights. I'll need to do some measuring to see if the 770 would fit on my panel (I'll attach a pcture of the current 496).I just swapped out my 496 with AirGizmo's panel dock for the 760 and panel mount. Tight, but it works.
I overthought this for months, as I haven't done much XC flying and didn't need the utility. However, a few weeks ago I tried with the starlink (no longer an option) and iPad, and it was pretty close to useless if you're actually maintaining any kind of traffic watch. The sun beaming down through the beautiful RV8 canopy makes the iPad all but unreadable- at least with my mounting options.
Also, I resisted spending the money because I am considering an engine monitoring upgrade and by the time you buy a dedicated engine monitor and a 760 (and GDL50R), you could argue that your halfway to the cost of a G3 display.
Also frustrating that I can't do the Stratus upgrade for ADS B in as it won't talk to Garmin, only the iPad. So same boat as you, I need the GDL50R. Which means drilling another hole in the belly and running more wires everywhere. (Minor, I know).
Silver lining is that with my current setup, if I invest in the GDL50R, my upgrade path could be swapping out the Dynon D10A for a G5 and swapping in Garmin servos, which would give me capability to GPS Nav from the 760. And the upgrade path from that would be swapping out the whole mess for a G3, still utilizing the Garmin servos and GDL50R, and put the 760 in the rear cockpit and use the synthetic vision feature which works with the AHRS in the GDL50R for the eventual co-pilot.
None of which is actually needed as I seemed to be doing quite fine with my 2005 database 496 and iPhone running Garmin Pilot- but then what fun is experimental aviation if you're not taking everything apart between flights?
Hi, I have just installed a 660 in my RV 6 & have found pros & cons. Firstly my reason for the install was to interface with my uAvionics AV 30e & because I wanted redundancy for my iPhone/ipad. I also want a stand alone autopilot (down the track) & the 660 will also interface with it ( at a cost). I like the intuitive menus but to get full use from the system it does need some practice. I installed mine on the panel with the bare wire kit & it works well ( no external antenna needed), for VFR navigation it’s great. It would be good if they had an internal adhrs like the 760 to use the synthetic vision . One of the main reasons I bought it was the operating parameters, much more +& - temp range, it will keep going long after an iPad temps out. Overall a great little unit.
