The VAF News - 3.19.2026. #6513. More RV news than you can shake a stick at.
DeltaRomeo
doug reeves: unfluencer
Staff member
OFF TOPIC:
Past ‘VAF News’ issues:
I won’t be able to sleep until some corrects the last screw to the 9:00-3:00 position. Seriously.
How could you miss the switch on the left isn’t the same as the other two (no on stamp), the middle switch is crooked, and the right switch is inset more than the other two? You won’t be able to sleep for at least 3 more days after you look. 🤣
Maybe an additional day when you notice the top middle screw is also proud and not screwed until seated (notice the shadow). 😂
OMG, you might be close to a week when you notice the top right screw is over tightened and distorting the plate since the switch is too far inset. 😳
It’s definitely going to be a week. The top left and bottom right screws are also not set (shadows again). 🤣
If I was a betting man, I would bet the cover plate is a new replacement since the paint on some screws are chipped indicating reuse, there are no scratches on the plate, there’s dirt from use on the switches, and the wall clean is clean suggesting fresh paint so a new cover plate would be in order.
But hey, I feel your pain about the last screw.😁
And don't forget that at the top right screw, the plate is starting to crack.
And the FOD in the paint above the switch.
If these are the switches that goes into DR’s shop, I hope we don’t get banished.
