Hey guys,
I've just started avionics. Section 42MS/U-08 asks to enlarge two holes (each side) on the center fuselage channel, as required. I'm unclear why it's needed, because when reading ahead to later sections, the snap bushings called out seem to fit the current hole size. Maybe Vans changed the wiring so it's not necessary?
I haven't put the main harness in yet, so can't tell if any wire terminals will not pass through the holes. Just wanted to check with people with newer IS kit. Thanks!
