Welp at 1,250 hours I finally got bit by the dead mag gremlin. Can confirm the symptoms mentioned here of the heartbreaking Death light, (the amber flashing). coincidentally my Tach reading was on this mag, can confirm the zero rpm readout. I was stranded twice. Ive learned you can cheat and likely get lucky by working the prop by hand....i discovered if you wiggle the prob backwards a little.... you can fake out the sensor enough to essentially get it out "Shut Off" mode. FYI, if you can fire up and both mags run, they won't shut off during flight, however Do Not do the Mag check at run up cause you could end up right were you were before. They only shut off when on the ground and self diagnose upon initial power up. Hence you can fake this to get going. You know, so i can work on this in my AC'd hangar! Anyways, Sending it in for overhaul. Ill report back on time and details of the process-that is starting today. This is a good thread topic, descent comments posted on this one. Mostly helpful. Call into tech support at Hartzell has been great too btw! Be nice to those guys, they have taken on a bit of a mess (to put it kindly) from the transition. Hartzell is fixing alot of caveman stuff in the background guys, that was not being done in the before era. Give them a chance.
