This is from a recent in-flight mag test. I was flying slowly, taking full advantage of a nice tailwind by putting along at about 7400' density altitude, 20" MAP, and 7.3 GPH, 2400 RPM, 148 KTAS.
The hump on the left is when the right mag was running, and the hump on the right is for the left mag. I get a much higher EGT on cylinders 3 and 4 which indicates to me the fuel burn is not as efficient as in the other two cylinders when running on just this pmag. I guess it could be two weaker spark plugs, or two spark plug wires that are not working as well, or the coils - I believe that a single coil serve 1&2 and the other coil 3&4 - but I might be wrong. Happy to get your views before I attack it with tools this weekend.
