liuk
Hello all, I have an RV-6A with an O-360-A1A and two Slick magnetos that has been running very well for the past few years. During run-up mag checks, I typically see a 70–90 RPM drop when one magneto is switched off. This past weekend, however, I noticed a large RPM drop (~200 RPM) with significant vibration when I switched off the left magneto. Switching off the right magneto produced a normal drop of ~50 RPM. I repeated the test several times at different RPM settings and mixture positions, and the results were consistent.
For context: I re-gapped the spark plugs three weeks ago during an oil change, and completed a 4-hour flight afterward with normal run-ups and no issues in flight.
I downloaded the engine data from Dynon hoping to identify the problematic cylinder or plug, but interestingly, all four cylinder EGTs *drop* when the left magneto is switched off. I'm wondering whether this points to a faulty right magneto rather than a plug or cylinder issue. I'd appreciate any thoughts. Here is the savvy link to the engine data: https://apps.savvyaviation.com/flights/shared/flight/10490645/bed5f66b-6fb9-408f-a115-c285ce65191a. You can see I did multiple mag test over 10 minutes. The first test starts at 4:37 (left mag off), and 4:45 (right mag off).
Correction: all 4 EGTs drop instead of rise...
