I probably should have asked this question long ago, but can someone tell me why I'm getting a fair amount of oil in my filtered airbox, making a bit of a mess of things? This is on an IO-320. Every time I change the oil (which is every 25 hrs), the filtered airbox is a mess, requiring clean-up. I don't mind the clean-up, per se, but should I be worried about this? For what it's worth, it is probably oil AND some fuel mixed with it, it has a blue-ish tinge to it, different than straight, dirty oil.
The engine does not burn excessive oil - I top back up to 6 qts every 13 or 14 hours between oil changes. And it runs well, no issues with starting, hot or cold. Hot starting is of course not as easy as cold starting, but still not too bad (usually). The engine now has about 260 hrs on it, and this has always been a messy problem.
Thanks in advance for any insight.
