Correct, there is no whistle slot in what I see either. I think this was an AD for my old 172That’s proper. It drips onto the exhaust, not muffler, where it gets burned up, to a point.
I do not see a “whistle slot” in the tube in that picture which protects from freezing and a blown out prop seal.
So this only helps with freezing, not with oil though?That’s the right spot. I added a whistle slot. I haven’t ever seen it ice up in this area though.
If you want it you can use a 1/4 drill, drill a hole and then bend the hole with the bit to make a slot.
Thanks. I'd. like to extend this also. Any ideas on how to do so?One port of engine dehumidifiers are commonly coupled to this breather tube. If you plan to use one, or would like to be able to easily do so in the future, I believe it would be best to extend the tube out of the bottom cowling. Mine exits adjacent an exhaust pipe. Per a post above, mine also includes a whistle slot.
Yes it only gives another place for air to go in case the primary hole gets plugged with ice. I think the oil got a little more messy with this hole than with only the tube outlet over the exhaust.So this only helps with freezing, not with oil though?
I don't understand exactly what you are saying, can you say it again?It is you breather.
The racer's slice faces the wrong way and I found a dry engine after abandoning this common practice.
Aiming the breather at your exhaust pipe to vaporize the efflux is secondary to helping the engine breath.
In cold weather, you still want the whistle slot so ice cannot pressurize your nose seal.
Adding pressure by terminating your breather in the lower cowl seems like a great way to make leaks.
Fire away!
He's saying that the "slice" should aim aft so that the slip stream is creating a vacuum, sucking air out of the tube instead of pressurizing it.I don't understand exactly what you are saying, can you say it again?
Racer's slice?
This already terminates in the lower cowl, I assume by plans.
Maybe on the buildIf you install an oil separator off the breather, you won't have to worry about oil spitting out again! However, you still want to position the aluminum breather tube such that it's not getting pressurized.
That is my plan. I suspect it is the source of left sided trace oil in the bottom of the engine. I am focusing on baffle seal replacement to better direct air flowThe OP's breather as pictured is installed/aligned in accordance with the FWF guidance from Van's. I'd leave it alone.
Actually, I have an oil breather/separator (this one: https://www.aircraftspruce.com/catalog/eppages/hboilbreather.php) connected to the engine, and the tube extending out the lower cowl is the outside vent port of the breather. Anti-Splat makes one that seems to be more popular with builders.Thanks. I'd. like to extend this also. Any ideas on how to do so?
Whistle slot just like Vans says? Do tell.The engine shop in Winnipeg showed we an engine they O/H a few years earlier that had Air oil separator installed. The engine was full of rust from the moisture being returned to the engine instead of being jettisoned overboard. In places where it’s cold I would clean the Pelly every now and then and not take a change of moisture staying in the engine. I would also make sure there is whistle slot. Ie just like Vans says.
